AIR BAG MODULE CODING
Hello I am trying to code in a new air bag module.
Unfortunately i get an error when trying to code it in.
I get Error 31: Request out of range - Coding Rejected.
Any help would be appreciated.
Thursday,31,July,2014,12:48:02:06086
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: TMBBE73T5B9006951   License Plate: YY10LSV
Chassis Type: 3T (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Sporadic communication error 1000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 JB    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   H21 7128
   Revision: 42H21---    Serial number:
   Coding: 00190012040500080000
   Shop #: WSC 33361 790 00070
   ASAM Dataset: EV_ECM20TDI01103L906018JB 003001
   ROD: EV_ECM20TDI01103L906018JB.rod
   VCID: 73E50119DAA2EE86965-8026
1 Fault Found:
4710 - No Communications with Airbag Control Module
          U0151 00 [044] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Mileage: 92669 km
                    Date: 2047.14.05
                    Time: 11:37:28
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AS    HW: 1K0 907 379 AS
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 863D601609220000611406E9901A0082300000
   VCID: 8305D1D902025E06065-80D6
1 Fault Found:
01321 - Control Module for Airbags (J234)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 175
                    Mileage: 92669 km
                    Time Indication: 0
                    Date: 2047.14.05
                    Time: 11:37:30
             Freeze Frame:
                    Count: 16384
                    Count: 2
                    Count: 16384
                    Count: 8226
                    Count: 45056
                    Count: 0
                    Count: 65024
                    Count: 2560
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3T0 820 047 M    HW: 3T0 820 047 M
   Component: Climatic      150 0303
   Revision: 00006001
   Coding: 0000000002
   ASAM Dataset: EV_Climatic A01005
   ROD: EV_ClimaBasis_SK35.rod
   VCID: 3979F331B84E54D69C9-806C
No fault code found.
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 K    HW: 1K0 937 087 K
   Component: BCM PQ35  H+  103 0615
   Revision: 00103 AD
   Coding: 48990AB8A05BF1C04010008011000164427000AE532081605C0040000040
   VCID: 3979F331B04E54D69C9-806C
   Subsystem 1 - Part No: 3T2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 13051  22  0602
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 240510 05  54  0403
   Coding: 2730ED
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 227
                    Mileage: 92669 km
                    Time Indication: 0
                    Date: 2047.14.05
                    Time: 11:37:31
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.35 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 D    HW: 3T0 959 655 D
   Component: J234__    VW10 HI   2118
   Revision: 24019000    Serial number: 003LEP5GH9R8
   Coding: 0000000
   Shop #: WSC 00000 000 00000
   VCID: 428B94DD1D98170ECD3-8017
   Subsystem 1 - Serial number: 6332MTS640691310
   Subsystem 2 - Serial number: 6342MTS640571310
   Subsystem 3 - Serial number: 6351HTS62I3G89KJ
   Subsystem 4 - Serial number: 6361HTS6B26H89KJ
   Subsystem 5 - Serial number: 63727TS6CHNV79KR
   Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
01042 - Control Module; Not Coded
            000 - -
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 1K5 953 521 AE    HW: 5K0 953 569
   Component: LENKS.MODUL   009 0135
   Revision: FF010036    Serial number: 20100510300669
   Coding: 4080040000
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 70EF0E15ABB4D59E6B7-8025
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 3T2 920 911 H    HW: 3T2 920 911 H
   Component: KOMBI         H04 0405
   Coding: 410B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 377DF5098E5A42A66AD-8062
1 Fault Found:
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 227
                    Mileage: 94409 km
                    Date: 2047.14.14
                    Time: 00:12:58
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 0602
   Revision:   H27       Serial number: 130510F2000003
   Coding: E9807F0600020200003303
   VCID: EDD19761F486B876C01-80B8
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 227
                    Mileage: 94409 km
                    Time Indication: 0
                    Date: 2047.14.14
                    Time: 00:13:32
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0405
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EADB9C7D0D68AF4EA53-80BF
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 B    HW: 8X0 959 793 B
   Component: TSG FA        H09 0409
   Revision: --------    Serial number: --------------
   Coding: 011002208001001000
   VCID: 4C97BAE5EFDCD17E37F-8019
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 227
                    Mileage: 92669 km
                    Time Indication: 0
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 195    3001
   Revision: 00H17000
   VCID: 3169CB11A83E9C96249-8064
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 B    HW: 8X0 959 792 B
   Component: TSG BF        H09 0409
   VCID: 4B95B9F9EAD2D6463E5-801E
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 227
                    Mileage: 92669 km
                    Time Indication: 0
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3T0 035 161     HW: 3T0 035 161
   Component: SWING         008 0065
   Revision: 0H001001    Serial number: SKZ1Z2K6985561
   Coding: 050004000004
   VCID: E7DDE549167A9226BAD-80B2
Address 62: Door, Rear Left (J388)       Labels: None
   Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
   Component: TSG HL        H06 0409
   Coding: 010000200001001000
   VCID: 4E93B0ED19C0E36E59B-801B
Address 72: Door, Rear Right (J389)       Labels: None
   Component: TSG HR        H06 0409
End   ---------------------------------------------------------------------
