airbag light came on, MOT tomorrow
airbag light just came on and I have my MOT tomorrow... all I have is some crappy ebay reader and that won't clear it obviously.
I don't believe it :dull:
Fancy a trip to Hawkinge?
One requires VCDS doesn't one? :)
Put some tape over the airbag light then get it scanned
Edited by Toxicvrs
Unfortunatly it appeared there is a fault with the airbag ignitor or the wiring behind the dash (passenger side)
VCDS cleared it several times, but it came straight back.
Thanks Gizmo68 for your help :)
Took the glovebox out and found out that the connector pins for the airbag was all bent, I *carefully* bent them back together and connected the wire back on.
The light is now off :)
From the photo below it's still not sitting correctly. I guess a new airbag is in order?
It's done the job for now...
