coil pack fabia 2 1.2htp 70bhp
Is it possible/ advisable to remove the coil pack, for spark plug change, without the special VW tool, if so how do you?
You undo the wire going into it and just pull the pack upwards!
Use 2 broad flat screwdrivers, lever the coil up simultaneously on both sides, until its high enough to pull out by hand. They come out easy enough. Make sure you invest in a t bar plug spanner to remove the plugs
These are good, available from GSF, etc
http://www.lasertools.co.uk/item.aspx?item=102
you can get a cheap version from Tool station but it is a little flimsy.
A cheap version? Thats only £5.50! Haha.
