Found some led number plate bulbs that work, error free and nothing on the dash
Not a problem with mine either.
How the hell are you supposed to get the old bulbs out? My holders don't have any torx screws on them like my mk1 fabia did
Left hand side of the light units have a small notch in them, enough room to gently and carefully pry off with a flat screwdriver
Tried that but got scared in case I broke it, guessing I have to use a bit more force then
I got something like this. Nice effect, not too bright no errors no blown bulbs, unlike the normal bulbs!
I got a set of the 38mm ones from the links above and they don't fit. Too long so check your bulb size before you order guys
Mine were tight so I bent the metal ends of the holder ever so slightly and they fitted fine
As above, You have to bend the contacts outwards, work fine then.
Sent from my SM-N9005 using Tapatalk
