Replacing front shock absorber - need quick advice/help
Went to replace my front shocks on my VRS & got to the point where I needed to remove the spline bolt from the wheel bearing housing. However, after removing the nut I found that the bolt wouldnt shift, I applied WD40 & gave it a few (many) good whacks with a hammer but the damn thing wouldnt budge.
The problem I had was at the time I didnt realise that it was a spline head & didnt had a M14 spline drive to hand so I couldnt turn the bolt. (in my defense the picture below does show a hex head bolt & not a spline one).
But my question is this: is the spline bolt screwed into the housing & the nut is there to prevent the bolt from working loose or should the bolt come straight out once the nut is removed? If its the latter then I will probably need to take the car to a garage to get some oxy-acetylene applied to the housing in order to take the bolt out as that bugger aint shifting!
Thanks.
Edited by Chris Berry
The hub isn't threaded where the bolt goes through. Take the nut off and the bolt should come out with a bit of persuasion. Have you got a hub splitter as well to remove the suspension strut from the hub once you've got this bolt out?
sent from my Galaxy Note 3
Damn, the bolt has proper cold welded itself in!
I havent got a hub splitter, but in the past, on a similar job, I've used an old large allen key that has been ground down, just push it into the gap, twisted & the hub opens up.
Have you tried a blow torch on it? If you're replacing the strut then it doesn't matter if you heat up the strut as well.
It's a gash job that. When Ross fitted my coilovers he made it look easy lol. But when I put standard stuff back on I never wanted to go near my car again hated it for days lol. I just put mole grips on the head then just undid the nut. The bolt was stuck in there well but I do remember using tickling stick alot to get it out lol. Heat will prob help you out!
Cheers for the info guys.
Probably gonna take the car to a local garage and ask them nicely if they can apply some oxy to the hub and get the bolt out. I have a set of new bolts ready to go on.
Try penertrating oil instead of wd 40. Plus gas or similar. Apply it a few times preferable before work starts.
Got the bolts off with an air gun, damn things were properly stuck in; there was rust and dirt all in the bolt thread, properly corroded.
I think that this is where a lot of people fall down, once the area is doused with WD-40, the proper release oil does not find its way in where it is needed, keep it dry and add release oil as Bassets4eva said BEFORE WORK STARTS. The last one I did, was a repeat visit five years down the line, the bolt came out easily, needed to be held to get the nut off, but I could not split the hub using the proper (Laser) tool, doused the hub/strut area in release oil, waited 4 hours, still tight, repeated the process and left it overnight, hub opened up easily.
"The problem I had was at the time I didnt realise that it was a spline head & didnt had a M14 spline drive to hand so I couldnt turn the bolt. (in my defense the picture below does show a hex head bolt & not a spline one)."
I seem to remember, just to compound this issue, my proper VAG parts catalogue described the bolt as having a Torx head, which I had a "good" range off - I too was a bit annoyed to find it was spline and my set stopped at M12 - and this was over the Christmas/New Year holiday period so getting the right tool was not too easy!!
