Rear drum brakes.
I went for a vehicle inspection. It turns out that the handbrake isn’t working properly. The left rear brake is very weak, while the right one is fine.
Is it possible to adjust just the faulty one? How can I do that?
The handbrake engages too high. I don’t want to adjust it with the screw inside the car because that would tighten the right drum too much.
Help :)
On the MK1 fabia which I am sure will be the same or similar on yours there are slider wedges that automatically adjust in rear drums. They can seize or wear out. They have a gripped surface on one side and are held in place with a small spring. Skoda Fabia 5J MK2 Rear Drum Brake Wedge Adjuster New Genuine 171609705 - Picture 1 of 4
It could also be a failing brake cylinder or leaking cylinder and contaminated shoes or a sticking handbrake cable on the poor side. If the handbrake is high it would point to the adjuster not working. Either way they will need to be taken apart to check.
Alasdair
The main foot brake works fine. The braking force from the foot brake is OK.
  • Sponsor
The top end pivot will be seized on the plate of steel in the drum that the handbrake cable attaches to.
How can I adjust or repair it? What needs to be replaced?
  • Sponsor
You might be able to free it up if you take that drum off, disconnect cable from that plate then rotate it back and forth to break corrosion.
Add a few drops of oil to the pivot/rivet, between the plates.
Loosening the cable adjustment in the cabin by quite a lot is a big help when trying to remove drum. Retighten when work is done.
  • Sponsor
Red ring is the pivot that is often seized. Pink arrows show the movement which should be free and easy.
Green arrows shows the adjuster which Alasdair mentioned.
Edited by Breezy_Pete
Keep a note of which way the adjuster is fitted as they only work if fitted the right way round. Theres a bump at top but cant remember if it faces you or the reverse.
Alasdair
