Retro fit cruise control
I've got the kit for installing cruise control to my I.9 sdi and have got the new stalk installed but just needing help with the locations of the wires, Ive managed to get the plug in the foot well but a bit confused about the rest, also the part about the fuse confuses me, is there a complete guide anywhere out there or can anyone help? much appreciated, cheers
Have you checked the ecu is compatible with cruise control? I don't think the 1.9 SDI is.
its got to be spliced in to the ecu
PM Tech1e
I went through the grommet in the passengers footwell when i done mine (removed the glove box).  Then went straight up into the number '1' pin (i think it was the number 1 pin on the edu loom, think it was a white wire).  Solderd and heat shrinker it onto the existing wire.
Have a look at this guide
http://web.archive.org/web/20120420114550/http://www.fabia-vrs.com/technical-info/cruise-control-retrofit/
Or if that link doesn't work try clicking the link in the thread i made about retrofitting and the problems i had.  Its the 1st link in the thread.
http://www.briskoda.net/forums/topic/276964-confused-fitting-cruise-control/
**edit**
Thats strange none of those links worked and i literally just checked them to make sure they worked before i posted them, now they don't work.  Have a read anyway to see if you pick up any tips.
Failing that i dare say Tech1e will be along soon.  Good luck.
Thanks for the replies, ive heard about splicing into the ecu loom which I dont mind doing if its my only option and that link doesnt seem to be working think fabia vrs.com must be closed down now
all done now, just need to splice the white wire to the ecu, just unsure which ecu wire I go into, anyone know? cheers
