turbo swap
I've been offered a gt1749va  for a good price,obviously this will be quite different to the turbo fitted to my pd100.
Is this a straight forward swap? Im sure i remember reading about some pipework will need changing (intake/outlet??)
Straight on, no pipe work change needed
Thats good news
i think it may be on the golf platform that needs a different compressor outle pipe.
Golfs need "clocking" no change of parts. Just undo a ring of 6/8 bolts. Rotate x degrees anf tighten. Will be obvious when you remove old turbo. Usr that to judge how much to turn
Thanks fletch,the turbo is from a Golf,fortunately my friend is better a this sort of stuff than i am and has mention "clocking"
My friend insists il need to change some pipe work as i currently have a vnt15 fitted and il be fitting a vnt17 and the compressor outlet is a different diameter ....i'm confused
I fitted a vnt17 to my pd100 where there was a vnt15 with no need to change pipe work.
Pd100, pd130 and pd150 are all identical I believe.
