twin rear fogs
What do I need to wire both rear fogs together, do I need bulb plus holder or just the wire.
Do you have LED or normal tail lights?
Edited by Black_Sheep
For the LED lights the bulbs and wiring is in place - just need to recode using VCDS and cable. Details here:
http://www.briskoda.net/forums/topic/299424-octavia-iii-vcds-adaptations-tried-and-tested/?p=3567267
A list of VCDS owners is here:
http://www.briskoda.net/forums/topic/224376-vcds-owners-map/
Not too sure about normal tail lights but I'm sure someone will reply soon.
Both mine work, LED lights, enabled with a VCDS
Don't wire them together!
Sent from my HTC One_M8 using Tapatalk
Normal tail lights, why shouldn't I wire them together?
Because the BCM is expecting to see 1 21w bulb on that channel. When it sees 2 of them one of 2 things will happen, it will throw a bulb warning light and shut the channel down to protect it, or you will damage your BCM.
If you want to go ahead and invalidate your warranty with a bodge job by all means wire them together.
The correct solution is to do the coding for the second fog light channel.
Havent got access to vcds so was hoping to wire them together, not found anybody near to me with vcds.thanks for letting me know about damage I could of caused, notsure why you think Iit would be a bodge job though
Can both normal fog lights be set by VCDS Andy ?
Contact Andyvee, he lives not too far a way, Top bloke, did mine for me
Yep - was the second thing I worked out after the cornering fogs for the vRS :)
There are plenty of people on the M62 corridor with VCDS - have a look at the VCDS owners map
Trying to get you you favorite tipple Mr V
LOL
A nice bottle of Shiraz :)
Mr Vee, if I travelled to you would you be able to do my coding for me? Mk3 octy vrs. Shiraz a plenty!
....or Rioca
I would indeedy :)
Drop me a PM
New here. How do I do that? Sorry
When I use link to vcds map it doesn't show anyone!
highlight andyvee's name on  the left of the post and click send message.
