Fitting hids
Thought I'd bump this rather than start another hid thread.
So I fitted my h7 4300k 55w from hid-direct today, easy little job in the end, found a hand video on youtube prior to fitting that showed how to fit without cutting the bulb clip retainers and I made a 21mm wad punch to cut the hole in the rubber cap for the grommet and Bob's your uncle they work a treat! Link for the youtube vid here
You got any pics of the 4300k? Not seen them in the 'real world' before
Sent from my SM-N9005 using Tapatalk
  • Replies 221
  • Views 14.1k
  • just to say i fitted mine at weekend, difference is nigth and day ( pardon the pun)  I fitted 5k canbus ready terminator ones from HID's direct.  They match the leds perfectly, light output is stagger
  • Just ordered the kit as to recommended by wrighty only difference the 5k version [emoji106]
  • Just installed the 55W 4300K kit. Had to cut the original metal bulb holders to pass the wire through, which I did not want to do but could not be bothered to get the e-bay ones and I only had some ti
No pictures yet, will try remember to take some tonight, I went for 4300k because I wanted the maximum amount of light, have a look at this link, can't remember how/where I came across I but it is interesting reading http://www.mobilehid.com/3000k.htm
The 4300k is very oem looking, not blue at all, the drls still show a small hint blue, maybe 5000k would be the perfect match but on reading the link the light output just starts to tail off, I'm well happy as they improve the appearance of the car no end and by god they are bright, really throws the light much further on main beam and no more driving in your own shadow because the car behind you has better lights on the low beam.
So fitted hids yesterday and the passenger side has stopped working today switched back to original and still not working what could be issue? [emoji107]
the fuse?
Any idea which one it is ant please?
the fuse?
Your right phew swapped them round 57 and 58 off to petrol station to find one [emoji106][emoji106][emoji106]
Beat me to it!
57 is left low beam
58 is right low beam.
Not phew just put in new fuse and blown the new fuse aaaaarrrrrrggghhh what could be causing this
Have you got the Hids in?
Yeah both in mate
Yeah both in mate
it's the ballast that has failed buddy I had the same problem
Cheers ant I thought as much I'm well p*****d off only had them a day [emoji36]
+1 Ant
Sounds like a dodgy ballast.
What hid kit did you go for/where from?
I resisted temptation of the cheap eBay options and went for a kit from hid direct in hope that if there is/was a problem then they would be easier to deal/liaise with to rectify any issues as customer service is high on there priorities.
Schoolboy error on my part went on gumtree and found someone local selling them brand new across the region, I wished I had gone to someone reputable now, which kit did you purchase?
Ahh, we've all been tempted with cheaper alternatives and regretted it, I tried some led H7 bulbs from eBay last year and regretted it, luckily the seller was very fair when I contacted him and I got full refund.
The kit I went for was hid direct h7 - 4300k - 55w
Lesson learned for me I've messaged the chap twice so far no reply, can I ask what you paid for the kit ?
That sucks, some people shouldn't be allowed to trade.
I paid £55.95
Here is the link
http://www.hids-direct.co.uk/h7r-55w-slim-smart-canbus-hid-xenon-conversion-kit/
Choose the temperature, I can recommend the 4300k for light out put but if you want the blue tinge then you will need higher but I'm no expert, that's just from all the hours of reading I've done.
+1 for Hids direct, got the ultra slim kit for £40 and had a small fault with the bulb and they sent me 2 bulbs out the next day! Top service.. I went for 6000k and very happy with it
Another here for hids direct.
I went for 5000k. They match my led sidelights perfectly.
Been in well over a year now n are still going great
So I fitted my h7 4300k 55w from hid-direct today, easy little job in the end, found a hand video on youtube prior to fitting that showed how to fit without cutting the bulb clip retainers and I made a 21mm wad punch to cut the hole in the rubber cap for the grommet and Bob's your uncle they work a treat! Link for the youtube vid here http://m.youtube.com/watch?v=W-EWIipji4U
Nice guide just bought the same kit as you did :)
Have I gotta make a batch of 21mm wad punches now? Glad the info has helped, i hope that the kit's don't disappoint!!
What's the advantages of HIDS guys over normal bulbs?? I'm looking at getting some but someone recommended some Philips I think, are HIDS much better?
Brighter, look better, last longer.
If you want normal bulbs then the Phillips extreme vision or osram nightbreakers are the way to go.
Or you could go the full hog on a hid kit
