What do people think of these? (Suspension)
Had a look at all of them
Personally I would get some h&r springs with some beilstein shocks
depends what you are using the car for
and if u have a drop height in mind yet
Coil overs I belive give a stiff ride
Someone will correct me if I'm wrong
I had koni str.ts on my fabia. I didnt realise the springs where h&r?
P.s i didnt have a problem with them. They where great.
Bilstein B12's (Eibach 30mm springs) for around £465 delivered.
I keep seeing the bilstein/eibach mix being mentioned. Its a bit more than i was planning to spend really, Ideally I wanted to keep it nearer £300 than £500.
I'm not exactly going to be using this as a track car it is just my daily drive, but the standard suspension is **** IMO
Im having a B12 kit fitted this week
Mine isnt a track car either, but this is far better than standard and a smooth less choppy and not too firm ride
save up for the B12 kit as it is the trick mono tube dampers that makes the difference
+1 but I only paid £372 somehow!
B12 kit £251 eBay, Eibach Springs £121 delivered.
Edited by billywhiz040480
Good find then! Brand new? Even for the B8 dampers on their own you're looking at nearly £400 now from overseas. The full B12 kits from Germany are nearly £200 cheaper than here, scandalous!
Sent from my iPad using Tapatalk HD
I was going to get the Koni kit (yes Mikejay , H&R springs) for my Leon FR, but ended up going for Weitec (Now ST Suspensions) by KW because of lead times. Koni kit was going to take 4+ months becasuse they were moving factories or something in Holland.
The KW kit was absolutely awesome. Totally transformed the car.
Also no one has said anything about any of the coilovers linked above.
Another question, my car is a 2008 2.0T fsi what size is my front strut 50mm or 55mm?
ALL vRS models are 55mm diameter
Yep brand spanking new and they came with H&R blue springs but unfortunately they were the wrong front end weight for my Octy. I sold them for £85 then purchased the Eibachs.
Impressive!
Just out of interest, does anyone know what are the weight limits for a F/L VRS hatch off the top of their heads?
Second that. Got h&r 55mm drop springs and Bilstein B4 (Sports) dampers.
Brilliant look and feel.
The AP coilovers get good feedback on this and other forums.  They are a KW brand btw.  I had weitec hi-con gt coilovers on the last vrs and they were very good - ride very near stock but with height adjustability - these are the same kit as the AP coilovers just with different branding and finish.
Having said that, tbh if you don't need the height adjustability of coilovers then a spring/shock kit is the way to go, and you really can't go wrong with bilstein/eibach  - only thing to be aware is that they don't drop the car much, 15mm or so is all you get.
HTH
It just depends on the spec of the spring and damper.
As above, my weitecs were near stock ride quality, slightly firmer but not crashy.  My bilstein b16 coilovers on the other hand were too hard for road use IMO.  My h&r monotubes were lovely, better ride quality than stock.
Impressive!
On my VIN plate, it has 1 - 1030kg and 2 - 940kg. Am I right in assuming that 1 is front and 2 is rear? If I was looking at suspension kits, I'd need kits with a weight rating of what? Up to? From? Thanks in advance.
HTH
how about the AP shocks and springs?
I have no requirement for height adjust-ability. so no need for coilovers really.
i don't know anyone who's had them unfortunately.  Given the good feedback the AP coils get in terms of ride quality i'd expect the shock and spring kit to have a simlar setup though.
Hmmm I may go for those as they save a considrable amount lol
What do people think of the below? Experiences of any of them?
Did you eventualy get the AP shocks and springs? If so how do you like them compare to stock suspension? Any pics?
No i'm afraid i didn't it's all gone a bit tits up and my octavia is for sale instead :(
