yeti central locking problems
My Skoda yeti 2010 plate has a problem.  The right hand side doors won’t lock electronically with central locking/fob. The driver door can locked with the key. The windows on the rights hand side won’t open/close either. The right hand side mirror can’t be repositioned with tilt control and the indicator light on mirror does not work.    Left side of car responds to central locking and widows can be opened/closed using control on each of the individual windows.  The mirror can’t be controlled but signal light does work. On top of this I have an orange bulb warning light dash display.  But there is no obvious bulb defect, they all seem to be working fine. Any advice and suggestions would be greatly welcome.
I have just experienced the same problem with my Yeti which is just out of warranty. It  must be a design fault with the wires chaffing in the rubber cover at the bottom of the drivers door. Skoda should repair FOC. It is happening a lot on the Yeti's
Anybody knows the OEM part number for the driver' side door loom please?
Unfortunately I'm having the same issue...I've actually managed to partially repair it but I've now got an airbag warning light on the dashboard (another wire broke?) so I'm thinking of replacing the loom all together...
I have found several part numbers but I'm not sure which one I should be getting
http://www.partsbase.org/parts/sko-5l0971121de/
Any help will be highly appreciated
