Boot Net
The net in the boot on the o/s has decided to collapse. Does anyone have the part number for a new one?
Sent from my Galaxy S5
I don't have a part number but I bought both off eBay last year for £36 pound
The small vertical partition one? Not listed on any Skoda site I've seen or on Partsbase either. Possibly be on ETKA if someone can access it. Could you not just make it taut again?
Sent from my iPad using Tapatalk HD
Yer the one on the side. The plastic frame is twisted and the metal bar along the top is bent. Have seen on the fl models it's one plastic unit
I think the net partition is an integral part of the O/S boot trim and not available separately.
Ahh right. I can't find anything on ebay or Google about it
Correct, there are a few part numbers for the trim, ones with mesh partitions, ones without.
Any part number should be visible on the original item if you look carefully.
Darn can't be brought separate then
Doesn't look like it, which is strange as its not all one piece. You could try calling your local stealers or TPS for a definititve answer. I suggest TPS as they always come across more helpful!
Thanks Jack that's what puzzled me before. Using a thin piece of metal across the top is a silly idea. No wonder fl models are all plastic
