coolant temperature sensor
Hello,
I have a 2002 fabia 1.9TD estate, I need to replace the coolant temp sensor. The engine code is 6Y5.
I have been advised not to buy a cheap copy, as they can be troublesome, however I hear that Febi Belstein are quite good.
The part number for this is 29318, they are a german manufacture, however I read somewhere that there is an upgraded sensor that is green.
When researching this, they seem to have 4 ports, not 2 as the grey one has, does anyone know of this upgrade?
Many thanks
Sean
Hey Sean, that's not the engine code. The engine code is three letters.  You're definitely better off buying a genuine Skoda temp sensor.
Thanks for sending this, but that is a four pin and Im sure mine is 2 pin.
Do you know who makes the darkside sensor?
I had heard that the genuine sensor was the best, but I think Skoda do a green sensor now which is not to be so problematic?
Trouble is your car is not wired for the four-pin sensor so you should get the grey two-pin. End of.
What I was meaning is there a upgraded 2 pin available.
Nope, just buy genuine.
ok thanks.
