no power steering
SKYHAWK
All fuses checked, Continuity of all wires to the angle sensor checked with no problems found. although theres no lights on the dash the angle sensor code is present however when diconnecting the angle sensor and starting, light illuminates on the dash.
Power steering should also work once the sensor is disconnected, the pump should run all the time the engine is running. Please confirm.
Once angle sensor is out, PAS system dies.  The pump is basically put in to its equivalent of limp home mode.  I had to run my car like that for 3 or 4 weeks whilst I was sorting out a complete replacement subframe/rack setup.
I thought it ran at a reduced level of assist unless the pump itself was faulty.
