Potenial Yeti purchase - advice wanted.
Hi All,
I am thinking of buying a Yeti, diesel, prefererably a 4WD version. Looking to spend about 12K so a quick look on autotrader means it's going to be in the 09-12 range depending on spec level.
Now for some questions:
Do they have any common faults or areas I should be looking at? (eg last time I got a passat I was told to avoid a certain engine code)
Is the haldex unit reliable? - what version is likely to be in a 09-12 car?
Is it possible to retrofit a factory option like the heated windscreen? (I know most things are possible given enough money but I'm being sensible here)
Any other opinions or advice welcomed.
Cheers guys,
Rob.
