skoda Rapid
I have a situation when I start my rapid 1.4 DSG from cold I can here a click from behind the dashboard (drivers side).
The click occurs when I turn the steering wheel left or right. after about 10 minutes the noise has gone.
I've just wondered if its anything to do with a temperature sensor effected by the increase in power from the steering.?
After a grazed hand and spraying WD behind the dashboard cannot locate where this click is coming from.
I can live with it as its not constant. Anyone else got this issue?
This is a new one on me!
But, No Issues here?
Nope - new one on me as well - are you near any of us (noticed you've not filled in your location) so one of us could have a listen?
Looked at this topic under 'Fabia click noise' it may be coming from near fuse box and it may be a relay.
As you turn the wheel from side to side there is the normal rev increase (power steering) and thats when I here this click. It goes after the car is run in after 10 mins. Annoying to start with and temperamental.
It must be something to do with fuse relay.
Edited by David69Rapid
