service message!
had my yeti serviced but the garage forgot to reset[none dealer] what is the easy way to do it myself???
regards
Michael.
No, has to be done by either the garage or someone with VCDS. Personally I'd get the garage to do it and check if they've forgotten something else!
I'm sure you can reset it yourself although the system warns you not to do it
It is in the Maxidot menu under vehicle information
What you can't change is going from fixed to variable servicing or vice versa
Edited by yetiscot
thank you for your replys gents,,sorted now :clap:
