fabia door locks
Hi all, getting worried that my rear passenger door will deadlock it's self shut.
Messaged a few of the fabias been broken for a replacement without luck. Can anyone tell me if there are any alternative cars I can get this from (occys etc)? And if possible a pic showing the exact part I need to replace?
Thanks!
Kyle
Thanks!
Kyle
Iirc it's only a Fabia in this type, mine dead locked it's self shut, took a few hours of carefully smashing into the lock to twist the gear to undo it, utter pita
That's what scares me!
Not sure the exact part I need either, so can't even start the eBay process!
Only one type on the Fabias isn't there?
That's passenger rear in pic btw ^^
Cheers that's a real help, there's about 10 listed on there, would the front and rear be the same? So as long as I get one with central locking it should be ok?
Was thinking of this one 3B2837015AM
Also noticed that when my car locks its goes 'thunk thunk' as if it's locking twice, the locks kinda twitch twice as well, is this the same as anyone else's?
Front and rear are different, and yeah central locking, the double clunk is locking once and then the deadlock :)
Thanks toxic, you are a gent
Does it sound like mine did?
I definitely had to replace it before it deadlocked shut.
definitely not as bad yours there softscoop. It's drops then kinda twitches on the second noise.. if that makes sence.
Toxic, don't suppose you still have your old lock and could get the part number for me ?
Nope sorry it got sold to someone on here, I'll have a look for you now.
I was repairing a deadlocked rear door, tapping the motor with a hammer, while mashing the unlock button got it to shift and unlock
but the mechanism was clearly chewed to hell, so we just swapped one from another Fabia (newer by about 3 years) and it worked fine.
I had to smash a hole in mine and twist gear
i got full set of locks front and rear if needed pm me
How much for lock set posted please steveopc ?
You need to get 5 more posts on here before you can use PM, if steve doesnr have the bits I may do,
Just after a rough price for lock set as my key only does ignition not doors :-(
