Fabia estate boot light wont go out, where is the fuse?
Hi everyone, hope someone can help?
The boot warning light wont go out, I don't want a flat battery in the morning, is there a fuse that I can remove.
Thankyou
Hi
I have haynes manual it says f4 which is 10a thats for interior light. Glovebox luggage compartment light. If thats any gd?. Or do you mean its a dash light. If so could be faulty switch
You can always just take the bulb out!
He said the warning light. The warning light has no bulb, it's an LED which is soldered to the instrument cluster printed circuit. The problem is probably the switch in the boot lock.
As TMB says, probably the probe in boot lock not touching to push it 'off'. A bit of fiddling and experimentation - a no cost fix, most likely.
