Is it normal that the EPC and TCS are on before ignition?
Dear Guys,
Before I turn the key to ignition position I hold the key at position vvc for couple of seconds. I found out that all other lights are on and go off except these two lights keeping on until I continue turn the key to ignition position.
Is it normal for all FABIA? I see in the owner's manual that those  lights should be off after the engine is on. Those lights indeed go away after engine on. In this case , the car should be fine now.
  I just wonder if this happen to all FABIA or is it an indication of potential problem? or it's just a built-in function?
I am a rookie , so please forgive me novice question.
Best regards,
Edited by crazybeeliuzhe
Yes its normal, they should however go out once the car is started.
Thank you. Now i feel relief..
Do these 2 lights stay on while its been cranked but then go off after its started?
yes, they stay on when the key is in the middle position and go off after turning the key to ignition position(engine started).
Check if u get any error codes as mine does exactly that. Cant remember exaclty what the code is but its the dreaded load signal wire
Thanks a lot. I will check the code as soon as my ordered odb reader arrives.
BR.
Got mine checked n fixed today.
the wires was corroded n snapped clean off just near the battery.
But them 2 lights are still showing for a couple seconds after start up. [emoji17]
But I've cured my battery light now so i know its charging.
So 1 out of 2 aint bad.
Its progress at least .
hi, Guys,
i got my vag-kkl cable today and the bundled trial version vag-com. i got the follow result after full scan:
2 Faults Found:
16555 - Fuel Trim: System Too Lean: Bank 1
            P0171 - 35-10 - - - Intermittent
17511 - Shareware Version. To Decode all DTCs
            P1103 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
   Controller: 6Q0 907 379 G
   Component: ABS 5.7     FRONT   V40
   Coding: 00044
   Shop #: WSC 13765
No fault code found.
do you think there is anything wrong? what does it mean "Fuel Trim: System Too Lean: Bank 1"
the second fault makes sense because i am using the unregistered trial version.
Thanks a lot.
i will reset the error first and keep on watching. Hopefully they don't come back.
