Felicia clutch pedal 'assist' spring
The spring on the clutch pedal, referred to in the Haynes manual, as the assist spring, has broken which means the clutch pedal comes higher up than it should.  The clutch still works ok but have to lift foot higher to use it.   So I am after a new one - it is about 3 inches long with a hook at either end. Anyone know where I could get a replacement - is it a standard spring that a hardware shop would sell or sp,ething specific to Skoda/AVG.
Steve
Part number: 6U0721450 but I can't see that being too much use as it is a felicia specific number, and dealers don't have that many felicia parts now.(worth a try mabey)
Might just be best trying to source one from a scrap car.
Hardware shop isn't too bad an idea, but you would probably be lucky to find one with the same strengh/tension.
Hi there i had same problem and the spine is discontinued from skoda I went to scrapy and got one from a car there hope this helps
I have the bits you want if you still need them pm me clive
@rv125
You sell a lot of things in here. Are you a car parts dealer?
no and I give a lot away for free as well if I sell its cheep, I am a old school horder
