Intake flap motor part number... Will this one fit?
03G 128 063 R
Can someone confirm if this part number is a suitable replacement for the intake flap motor on a bkd engine?
Dan
anyone with etka able to confirm whether the 'R' variant is suitable for the BKD engine?
I have a 140 2.0pd TDI BKD 55 plate. Have stripped and cleaned the intake manifold. There are no intake flaps on it anywhere that I have seen. Where are they?
Or do you mean the Anti stutter valve?
Or have I missed something?
Not 100% as its not visible from the front id have to remove to see it, ill get it off in the next few days and check, i did put a post up a while ago about the fault code, and someone mentioned the original and revised part numbers i will try and find it,
Dan
Original is 038128063M now ive just seen the part numbers side by side im assuming the fact the one ive posted is 03G and not 038 might be the deciding factor, just need confirmation from someone with access to etka really
Dan
Edited by Dan Welburn
That's a really old part number mate. From back in 2006, and has been discontinued for a good long time. If it's a "new" part then it's been sat on a shelf for years, if it's a used part then I really wouldn't.
Oh, and further investigation says it's for the BMN engine. You know the part number you need for the BKD engine, I told you some weeks ago. :nerd:
its a brand new part but ill leave it no point risking buying a part that may not fit, found genuine pierburg ones for £100 delivered, so might as well do it properly and get all mechanical stuff **** on before i start with all the exterior looks of the car
  • 1 year later...
Hi That sounds like a great deal best I could find was £130 from Germany can you let me know where you brought this one from?  Ta.
Sorry for the slow reply been mega busy transforming my octy, i never ended up buying said motor, i ended up using a used one from a 1.9tdi octy that i had in for breaking, wasnt a direct fit though i had to modify the outer casing, i do however now have a a3 bkd in for breaking that i do have the motor from
