Interior blower
Hi guys,
I'm guessing this is the right section, so yeah my blower works but it doesn't seem to be that powerful or blow where it says it supposed to be blowing.
It's annoying at this time of the year as of course demisting the screen is a must!
Any advice would be great.
Rob
Start by changing the cabin pollen filter (under the LH half of the scuttle trim).
Thanks, I'll give that a try!
If it's only working on certain speeds it's probably the resister pack behind the console that is failing
Not realy any help but is it like mine it is rubbish on windscreen all the other settings seem to be fine though
Was gonna ask at some point but have just been living with it so far
Change pollen .give the inside of the screen a good clean...then close the 4 dash vents. Set to max heat set direction to screen . That's the fastest way i have found to clear the screen.
Edited by FLAPPERJACK7
if its not blowing where it says, id say the dash has been out at some point, the air pipe got moved, and so is out of sync with the setting.
turn blower on full, and then check each setting to see where the air is set to go and where it is going.
then you'll able to see whats what
may also be a loose fit if the pipe was moved causing the low output.
