VCDS mong - how and what to do?
Bcc212
So I'm borrowing my mates laptop and cable tomorrow to do a few bits on my car. I've never used VCDS before and never watched anyone use it.
So to that end, there's a few bits I'd like to do to mine and the wife's car. Namely:
Large MPH display
Needle sweep
Change power steering weight
Anti hijack
Change indication to 5 flashes from 3
Teardrop wipers.
I don't really know how to do it, so can someone give me a quick guide as to how to change the settings in VCDS.
Many thanks, oh and are there any other good things you can do?
For the large MPH once you've changed it to AUS on VCDS you'll need to go into the MFD and select the box for it to show on maxi and also change the units back to GB on the maxi.
Alarm beep for lock/unlock and all door unlock are good ones too
Edited by R1chard
So I've tried changing a few things and I get various error messages or bytes not appearing which should.
Module 44
Adaptations
for the power steering change says choose Channel 1 and then choose between 1-6 for increased weight.
It says channel 1 does not exist. Only channel 0 which cannot be updated? I'm not too sure if there's another way round this?
Did manage to put teardrop on though.
Did you have a look here: http://www.briskoda.net/forums/topic/236545-power-steering-adjustment/?hl=%20steering%20%20assist  ?
44 - Steering Assist
Recode - 07
Soft coding
112 X 1
Then you choose the 4th digit based on the description in the other thread. I have mine on 2 (that is: 11221) and it feels much better than stock.
Few points of reference:
5 instead of 3 indicator flashes is:
Module 9 centr/conv.
Adaptation 10
Channel 43
Change from 3-5 cycles.
Press save.
Audible beep on unlock/lock
Centr/conv. Module 9
Adaptations 10
There's a drop down menu, choose unlock
Change 0 to a 1
Click save
Use menu again, choose lock
Change 0 to a 1 again
Press save.
