HID conversion
Coz I'm a little chavy and my car is blue and with a slight blue colour to the Blubs is the look I want I was planing on buying h7r canbus free kit off ebay but the main beam is separate to the dipped beam Id like both to match without takeing the main bulb out and buying a bixenon
The OP wanted better performance on unlit roads.
In your case I've got an alternative idea though. Go to a local coachbuilder and ask him to mix you some Race Blue without the metallic particles in it. That will give you a matched blue tint that will still pass light although it may not be road legal.
  • Replies 59
  • Views 8.7k
  • Do you have the projector headlights designed for HIDS?   If not, don't bother, you'll just be a tool and blind everyone else on the road.
  • soul snatcher24
    soul snatcher24
    I'm pretty sure they do them for dual filament too, they'll be a different code though obviously. Try searching "Eric the car guy HID" or something similar on YouTube. I'm pretty sure he did a video o
  • Well, at that rate the quickest and cheapest way to get started with a Furbie is Osram Nightbreaker+ quartz-xenon filament bulbs, although I'd agree soul snatcher24's point about the new H7R plasma di
Personally I'd just buy Osram Nightbreaker+ .
Currently got them on my car and I don't rate them.
As there has been so many things suggested what am I actually meant to do?
Buy a h7r kit for the standard headlights?
Fit a projector to my headlight unit and buy a h7 kit?
Or something else?
Osram nightbreaker unlimited is cheapest, easiest, fair improvement
Projector retrofit then fit hid kit is about £100 but you get excellent output, a fancy cutoff and whiter light (5000k kit is recommended), but involves a little work (seperating lights, although it is really quite easy)
Buy depo projector units and a d2s hid kit, anything up to £400 for the units on ebay, but arguably easier to fit than the aftermarket projector, decent light output, bragging rights on the forum
Fit h7r hid kit, STILL blind everyone and look a tool
There's your options :)
That's a little excessive it's only the same as fitting led side/number/interior leds hids give out a nice light aswell as being abit safer as you can see further
And blinding everyone :finger:
As long as I can see im alright jack fu.ck everyone else ive fitting hid kits to all my cars and never really had a problem
Nice attitude to others :thumbsup:
I care enough to buy the h7r but not enough for the depo headlights and ballast
I've got these for my main beam:
http://www.ebay.co.uk/itm/MTEC-H3-12v-100w-Cosmos-Blue-HID-class-xenon-gas-bulbs-/370729314977?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5651306aa1&clk_rvr_id=781709858332&afsrc=1&rmvSB=true
Excellent light output and a nice white colour with a slight blue tint.
Cheers for the options. [emoji106]
As much as I'd like to get the best I don't have £400 to spend so guess will be retrofitting a projector. [emoji2] but just to be clear if I fit the projectors it's just a standard h7 hid kit?
If you fit projectors, you need D2S HID bulbs and not H7.
I see. Cheers for the help [emoji108]
If you retrofit projectors (not the whole depo units) it will be a h1 kit, as the projectors are "mini h1" units, that fit into your h7 hole with an adapter plate :)
Have a look on HID planet and Theretrofitsource for how to fit projectors.
Best option would be to work up a second set of headlights, then swap the bits out. Ensure you get a kit compatible with H7 original bulb though or you'll be doing more modding.
Ok. Thanks for the advice [emoji108]
I was thinking of doing the whole second set of lights but I don't drive my car from Friday morning till Monday night. Would Like to think I'd be able to fit it all in that time? Or is it a big job?
Easily do-able in that amount of time
While we on the subject of lights does anyone now what I'd need to change my rear number plate lights to led?
I just brought some festoon type led bulb from halfords for my number plate lamps . Works a treat .
Don't suppose you got any pics of them? Want a crisp white light not murky yellow. [emoji6]
Trust me it is a crisp white light . Not got any pics though and don't quite know to post them on here lol
Yea you need two buddy
Don't quote me on this but I think the interior ones are the smaller type 36mm
And don't suppose you know what ones are needed to do behind the dash board and the speedo?
