Issue Questions/ answers - new VRS
update,
Light switch box, replaced. Fogs working as the should
Interior light, had a dodgy fuse connection, fixed and working.
All bends and ss pipework arrived for top and bottom boost pipe replacement.
poly bush inner and outer wishbone bushes arrived
both side outer cv joint kit arrived
windscreen washers not squirting on window, need to sort this.
oil/ filer, fuel filter, pollen filter, engine coolant, disc and pads, brake all around, brake fluid all arrived and to be fitted ..
Fuel sender gauge issues, on inspection ... more electrical bodge job ...any ideas on how it really should be wired and what to do?
http://postimg.org/image/yile01g0r/
  • Replies 59
  • Views 4.1k
  • I'm not sure about the electrical niggles - it sounds a bit like it's been rewired by a f%^*wit sparky. Anyway - if you have ASR the button on the centre console says ASR. If you have ESP it says ESP
  • If you want your head unit to keep its memory, swap over the red and yellow cables at the back. Put the yellow with red and the red with yellow.
  • As above about asr Have you checked brake fluid level? As for headunit maybe somebody had a diff one in and tried to fit original and just shoved it in perhap cables been broken in process as im sur
Took this pic of mine. It's a 1.4 MPI but I presume the wires will be the same. The brown/white and purple wires look to have been swapped round on yours for some reason.
Ive swapped them now, didnt seem to change anything..
Why someone would slice a wire so close to the fitting ??
Seems like im going to have to change this sender unit!!
this is how 9am looked lol  http://postimg.org/image/uc3potwh9/ if the previous owner sees this you are a t**t cowboy!
I have a loose head light, discovered the main rear fix point has been broken off shown here
http://postimg.org/image/i89fufgel/
1 = snapped fix point
2 = snapped point on the headlight
3 =  screw missing
4 = bodged screw needs replacing with proper screw and washer.
Pic of snapped headlight fix point
http://postimg.org/image/5luh7hget/
So i think the worst is the main fix point, really not sure what can be done here, if i make a bracket the screw will stop the headlight going in...
Think i need a new headlight?
Also removed the ERG, with the intention of clean and refit... no chance, with these pain in the arse bottom screws.. what a tard of a job!!
I also could do with the measurement for the crankcase breather, and the air pipe, so i can order some silicone tubes... that was another bodged job with three different sizes of fuel line and garden hoses acting as a reducer to oil catch.
Another expensive time on this laptop, ordered Gates Timing kit + water pump, and aux kit + tensioner, and a ERG delete pipe.
Edited by FromTheDarkness
...and a ERG delete pipe.
EGR, Exhaust Gas Recirculation, EGR not ERG, an ERG is a measure of work equal to 10^-7 Joules, you're driving me nuts!
EEEERRRRRGGG!!
AAAARRRGGGGHHHHHH!
shh and tell me how to fix my headlight!
Bought a pair of headlights for £40, but need to source the top screws and the side screws
