Afs am I paranoid?
Hi
Had the dampers and top mounts changed a few days ago
On the way home tonight I noticed that the lights seemed to be not as effective, they seem to aiming low and not lighting ahead as much?
They seem to calibrate ok on start up and the cornering function is working, also when I slow down you can see them alter pattern
I wonder if they are related as they self level?
Also would assume I would get an error code if something was a miss?
Can't work out if I am being paranoid or not?
Check the level sensor on the ns of wishbone, as you need to disconnect the sensor to drop the wishbone to remove the front damper.
Thanks will check
Just found a pic that shows it on the Octavia forum
Do you know if it is disconnected would it chuck up an error code?
Ta
Just checked and it was disconnected
Popped it back in and it's all good. Knew I was not going mad lol
Can I just check if it does just pop in as it seems quite a loose connection, also just to double check there is only one sensor on the front on the passenger side?
Back at the dealers at the weekend so will mention it and get them to double check as it could have popped out or was never connected?
Thanks for your help
Edited by thinline1
There should be a sensor on all 4 wheels - the car needs to know where the suspension sits on all wheels to adjust the headlight level correctly as the load in the car varies.
there is just only one sensor on the front and one sensor on the back but the back one should be fine as they shouldn't need to touch it if they are working on the front only
The connection safety clip might be broken as most leads have safety catch before it can be pulled out. I don't normally remove the lead but just remove the nut and bolt instead as there is less risk if damaging the connector. If it does feel loose and easily pulled you may need to secure it with some insulating tape.
Thanks for your help guys
