How Do I Take A Positive Feed From Battery
Hi guys, just got the 15 plate Roomster. Had a look under the bonnet at the battery as I'll be wanting to run a couple pf feeds through to the boot. Has anyone got any advice about getting to the positive terminal of the battery please as it seems to be covered in red plastic case of some sort with several wires coming out.
Can't you use the power socket in the boot, or do you need more than 10 amps?
Ahh yes need more power as jezza would say. I use some radio equipment that needs a good supply.
Also been told that the cig lighter sockets are not switched with ignition too. I'll be fitting a pair of relays for my feeds too.
