VRS PD TDI 08 ISSUES ?
Alright folks....first post here for me....normally on scottshvag site for my bora 150 tdi ( smokey pd206  !! ).Going to look at an Octavia PD VRS...not the "CR" ( KW08 TYP )....Milton Keynes area......Any one know if there is anything I should be looking out for for this model, or even this actual car ( silver )?.....only 33k on the clock...black aftermarket multi spoke 18's - £7,900 trade. Cheers in anticipation of any haeds up nightmares to watch out for...other than usual potentail dpf issue.
best to avoid the PD engine on the VRS and try to find a CR one instead as there are too many issues if the injector recall was not done properly
Cheers for that. Much appreciated.Assuming recall confirmed as done, and not done properly do you think I would notice anything on test drive ?
Also another to watch out for, the DPF on PD engines are not the greatest
Cheers for that....and no recall for dpf either I believe !  and not cheap if needing replaced....same for most makes  / models with dpf's I'm told though.
10/10 sir. top advice. seems that every high powered diesel you look at has some sort of issue...but the CR 170 looks worth looking into as suggested...or mapping the 140 as you say..........I'm starting to think the pd 170 might be a bit of  a  risk, even if injectors / loom / dfp replaced. tahnks agin very mush for you advice and the link. All the best.
