Direct Firmware Download needed for Bolero in Octavia III
I'm unfortunately in this boat too.
A PM link would be fantastic.
  • Replies 52
  • Views 23.4k
  • Don't listen others. Show more information for your Bolero (SW, firmware number you will see if hold CAR and MENU button simultaneously). By the way MDI is coding feature of 5F block. Could you give
  • My dealer also mentioned that he believed that the Columbus would get mirrorlink throug a update. But I wont believe it untill I see it.
  • *doublepost *
Hi all,
would any body be able to help with a link for a firmware upgrade please for my Bolerosterio ?
thank you in advance
24 minutes ago, coopster said:
Hi all,
I can PM you a link in a few moments to update you to 0490
thank you sooooo much Varooom ❤️
picked up my first vrs last saturday - happy out i love it
Hello Everybody!
Very new here. Could somebody please help me with a link for a firmware upgrade for my Bolero?
Also could i add a Bluetooth connection option?
1 hour ago, 1vr15t1 said:
Hello Everybody!
Welcome to the forum, I will send you updated file.
Perfect. Thank you!
Hi everyone,
would anybody be able to help with a link for an upgrade?
Installed SW Train Version:  MSTD_EU_SK_P4320
Installed SW MU Version: 0435
Part number: 5E0035842A
Software version: 13.41.18_H15.10.138_STDPlus-EU
Thanks a lot. (Photo of settings in my native language Czech sorry about that)
On 29/01/2021 at 06:26, pab567 said:
Link sent via PM
Hi @pab567
Grateful if you could PM me a link for latest firmware for 2013 Octavia Head Unit 5E0035842A. software version 0407.
i have the following VCDS scan for module 5F
Address 5F: Information Electr.       Labels: 3V0-035-MIB-STD2.clb
Control Module Part Number: 5Q0 035 840 C    HW: 5Q0 035 840 C
  Component and/or Version: MU-S--ER      H41 0475
           Software Coding: 03735100FF00000051510004001100002F0201F60120040003
            Work Shop Code: WSC 00078 790 12345
              ASAM Dataset: EV_MUStd4CTSAT 001022 (SK37)
                       ROD: EV_MUStd4CTSAT_VW26.rod
                      VCID: 2D0704C61D9F2CD2C45-8078
1 Fault Found:
1555 - Check Software Version Management
          B201A 00 [00001001] - -
          [Check software version management]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 185
                    Mileage: 306287 km
                    Date: 2024.05.08
                    Time: 00:58:47
                    Voltage terminal 30: 13.2 V
                    Status_Software_Version_Management-module_name: D
And the photos taken for the screen unit attached.
can you please help me identify the real problem and advise a solution?
@pab567
Edited by MohamedElGazayerly
Looking for lastest firmware :
Device: 5Q0035840C
HW: 041
Software: 0472
Media Codec: 4101.0.0.0
Hello guys
I have a 2016 Octavia with the Bolero(MiB2) system. I managed to update the version with a memory card to 0253 (MST2_EU_SK_ZR_P0253T), but further versions are no longer allowed: "unable to read file meta-information" error. There is only an SD card reader in the glove box. In summary – have I understood correctly from reading pab567’s posts that in reality, without intervening with a soldering iron or replacing the system in the glove box, nothing more can be done there, the software cannot be updated further, and SmartLink cannot be made to work? I have OBD Eleven*
Br,
Jaak
43 minutes ago, Jaak_Angus said:
Hello guys
Br,
Jaak
@pab567
45 minutes ago, Jaak_Angus said:
Hello guys
Br,
Jaak
@pab567 Hi. Sorry that I didn't mention You here with @ before and now trying to get your attention like that :)
Unfortunately you understood correctly
I don't deal with aftermarket units so can not give my opinion on any of them, sorry.
Tnx. Maybe to keep my eyes open, if some used Amundsen comes to market? This should be possible solution and may work?
Br,
Jaak
Yes, Amundsen MIB2 unit can be reworked (activated, CP removed) using SD card only ) MIB STD2 TOOLBOX is the keyword...
Im sorry to spam here but I can't still send PM's. For that, I need both things yes? Glovebox unit and display unit?
Br
Jaak
Nope, just glovebox unit, SD card for maps (32GB recommended so you canhave the whole Europe on single card) and internal GPS antenna.
5Q0 035 874 A is good to go? One is right now on my local market ) Or should wait a bit and try to find newer version?
Br
Jaak
Yes, it is OK )
19 hours ago, pab567 said:
Yes, it is OK )
Aaaaand Im late :D One lucky guy got it before me :D U don't have these units to sell? Soon I'm able to DM hopefully.
Unfortunately not, but you can search allegro
