Direct Firmware Download needed for Bolero in Octavia III
Hi,
I need direct download link for Skoda Octavia III (2014) Bolero MDI
Please help.
I tried getting on the update portal however there were no upgrades available. There is some problem with my firmware and hence I was wondering if anyone could help me with a direct download link /  torrent link for the firmware. Also if anyone has been able to download the latest update for the same from update portal please share your VIN which I could use to download the firmware directly from the update portal.
Thanks & Regards,
Kashyap Jain.
  • Replies 52
  • Views 23.4k
  • Don't listen others. Show more information for your Bolero (SW, firmware number you will see if hold CAR and MENU button simultaneously). By the way MDI is coding feature of 5F block. Could you give
  • My dealer also mentioned that he believed that the Columbus would get mirrorlink throug a update. But I wont believe it untill I see it.
  • *doublepost *
I believe this is something only a dealer can do. Or possibly someone with a vag can pro setup. The firmware updates seem to require authorisation from skoda uk before being implemented
Snet with speeling mistkaes from my phoen
I don't think its possible to "officially" upgrade the firmware on any of the entertainment units yourself.
The update portal only provides map data (not software upgrades) even for Amundsen & Columbus.
If you think there is a problem, you have to convince your dealer to upgrade it for you.
Firmware Upgrades are from dealer only.
IF you manage to get hold of the source files and perform the upgrade yourself you will then have an error code logged for SVM that a dealer will have to clear for you (or someone with VCP, as VCDS can't clear SVM errors)
Could you give more information about your problem (what is it)?!?
Are you saying that Firmware Updates are available outside of the dealer network. Apologies, but I am struggling to understand your post.
Sent from my HTC One_M8 using Tapatalk
Hi,
Please help.
Thanks & Regards,
Kashyap Jain.
Is the car outside of its warranty period - I'd have thought a 2014 would be still covered unless you've done mega miles. If you have a problem then your dealer should update firmware free of charge (just had mine done).
Actually the problem here in my Bolero System is that I can not see Mirror Link as one of the options, which is there on other videos I saw on youtube. However when I asked my dealer to help and update the Firmware, he said no updates are available with him. So I am looking for some download link from where I can download the update and process the same myself through SD Card.
Update should be available to the public at the website in June.
Is this an Octavia? Mirrorlink is not currently available as discussed at great length on here.
Where has this info come from regarding Mirrorlink being available as a public download for MIB1 units?
I think I've heard it from my Skoda dealer.
*doublepost *
Edited by Gromle
  • 1 year later...
Hi,
Please help Thank you
  • 10 months later...
Hello, I need link for Octavia III - Bolero , please help me.
  • 4 weeks later...
There's allready a complete thread on Briskoda about upgrading Bolero MIB1. Just use the search button, BUT there is not any mirrorlink update for the MIB1 Bolero and there will probably never be any. Forget about it.
On 11/10/2017 at 12:01, mailme said:
...there is not any mirrorlink update for the MIB1 Bolero and there will probably never be any. Forget about it.
There NEVER will be - Hardware does not support it.
  • 11 months later...
I also need download link for bolero system for octavia 2014 2.0 tdi at
it doesn’t have mirror link and
but if any one have direct update link please guide me how to update.
TMBBJENE9EA006758 is my vin so please guide me properly.
  • 1 year later...
@pab567 My dads radio has stopped picking up DAB radio for some reason. The option has just disappeared from the menu screen...
I'm wondering if a firmware update would fix this?
It's a Skoda Octavia Scout it's a 2015 model. The system settings on the the radio say:
Device Number: 5E0035020D
Hardware: 443
Software: 0370
Can this be updated at all? And is there anything odd about this hardware/software version on this model car at all? I find it odd that the radio has worked since 2015 and now is picking up zero DAB?
I'd greatly appreciate your help! Thanks. Paul.
I sent you link on PM but IMHO this is rather HW issue, not SW
Looking for lastest firmware :
Device: 5Q0035840C
HW: 041
Software: 0472
Media Codec: 4101.0.0.0
  • 3 months later...
Device part number: 5Q00358404
HW: H24
Software: 0241
Media Codec: 2101.0.0.8
I appreciate your help! Thanks. Paul.
HW: H24
Software: 0241
You will need to tag @pab567
because he doesn't mind read and also canny follow the numerous threads on here.
Link sent via PM
