Help with R32 front and rear brake setup
Hi all,
I have a set of r32 brake calipers (345mm front and 310mm vented rears) that will be fitted this weekend but I just want to make sure I know and have everything that's needed for the job. This is for a 2011 Octavia vRS estate.
So far with the help of Nobafett and some other posts on here I have worked out that the front calipers will need to be shaved to clear the alloy and also that I need new brake lines. Do I need new brake lines for the rears as well and is there anything else I'm missing or that's needed?
Which discs and pads have been tried and tested that would be recommended?
Thank you :)
Guest
