VCDS Tweaks for Mk3 Fabia
Coming Home / Leaving Home with fog light
LED-DRL dim when indicator active
DRL only on switch position AUTO
DRL off when handbrake is applied
DRL with Backlights
License plate Light with led without error message
License plate light dim when trunk is open
Activate Cornering
Speed when cornering get off
Both sided cornering deactivated on reverse
Fog light active when high beam is on
Drive Green Menu activated
Speed when park distance control get off
Indicator staging activate
Hill Hold activate and set up, how long it hold the brake
Warning signal off, if ignition is on and driver door will be open
Adjust Characteristic curve of steering (dynamic or comfort)
B)
9 minutes ago, Damo said:
@djduese that sounds fantastic, as I don't have the fog lights on mine either.
can you tell me how to do that as the guy with VCDS is coming to do mine tonight
From what he told me through PM, this should be the procedure:
- ECU09 (Central electronics)
- Adaptations
//-----L-----
- Leuchte 6 ABL LB44
- Light function C6
- Set "Coming Home / Leaving Home active"
- Dimming C6
- Set "0"
- Dimming direction CD6
- Set "minimize"
//-----R-----
- Leuchte 7 ABL RB5
- Light function C7
- Dimming C7
- Set "0"
- Dimming direction CD7
- Set "minimize"
If you have problems with low beams (flashing on and off), then you should do the tweaks in "Leuchte 12NL LB40" and "Leuchte 13NL RB3" instead of "Leuchte 6 ABL LB44" and "Leuchte 7 ABL RB5".
(please correct me if something is wrong)
Edited by yankarinRG
  • Damo unpinned this topic
Hello, does anybody know which bit on which byte should be changed for locking car while running in neutral?
I can't change anything through Adaptation, only through long code. Fabia 1.2 TSI Style 2017.
Thanks in advance.
44 minutes ago, mtl said:
Why can't you change in Adaptation? Also MY2017 cars have all adaptation options available.
Hi, it needs security access, and when I go to long coding, it doesn't show options just bytes and bits. Error was something like uninitialized module.
Any clue?
Thanks.
6 minutes ago, djduese said:
And what is the problem with the security access?
Most changes are done in adaptions.
What system do you use for coding?
I don't know what is the code for my Fabia 2017, for security access.
If somebody knows, that would be great.
For everyone, who has a Fabia 3 without Lightsensor and because of that no coming home and leaving home. With this coding, you can fake a ch/lh. That fake ch/lh works everytime, you unlock your car or open a door. fake leaving home works perfectly, fake coming home lights up till you lock your car.
In this coding, it lights up parking light in front and backlight include license plate light
I'm not sure, if the lightfunction is named Umfeldbeleuchtung or Umfeldlicht
Controller 09
security access: 31347
Adaption
Leuchte2SL
         Lichtfunktion G2 =  Umfeldbeleuchtung
         Dimmwert GH2 = 10
Leuchte3SL
         Lichtfunktion G3 =  umfeldbeleuchtung
         Dimmwert GH3 = 10
Leuchte4TFL
         Lichtfunktion E4 = Umfeldbeleuchtung
         Dimmwert EF4 = 127
Leuchte5TFL
         Lichtfunktion E5 = Umfeldbeleuchtung
         Dimmwert EF5 = 127
Leuchte20BR
         Lichtfunktion E20 = Umfeldbeleuchtung
         Dimmwert EF20 = 18
Leuchte21BR
         Lichtfunktion E21 = Umfeldbeleuchtung
         Dimmwert EF21 = 18
Leuchte23SL
         Lichtfunktion C23 = Umfeldbeleuchtung
         Dimmwert CD23 = 100
Leuchte24SL
         Lichtfunktion C24 = Umfeldbeleuchtung
         Dimmwert CD24 = 100
Leuchte25KZL
         Lichtfunktion B25 = Umfeldbeleuchtung
@Damo perhaps for your list interesting
Edited by djduese
  • Like 2
Has anyone here with my2017 fabia managed to get ch/lh work with DRL only? Having problem that low beams/fog lights still goes on/off for second, although they are set to minimize/0.
23 hours ago, SC03OTT said:
Surely you want the function to be 'Not Active' and not just set the level low?
By default it goes like this with my car (my2017):
1. Comfort lighting Coming Home leuchten: low beam/fog light, default is low beams
2. Leuchte6 ABL LB44 Lichtfunktion B 6: Coming home Leaving home
3. Leuchte7ABL RB5 Lichtfunktion B 7: Coming home Leaving home
so this is the factory setup and it uses low beams and drl (10%) as ch/lh.
If i set 2. and 3. to not active, ch/lh still works like from the factory. So 1. seems to be top priority with ch/lh.
So after this i tried to set 2and 3. to not active, and activated ch/lh again at channel c, so that i can set dimming to 0 and dimming direction to minimize (also tried maximize). So with this coding it works otherwise, but low beams still goes on/off for second.
Exact same thing if i try use fog lights, and then try to minimize/0 from Leuchte12NL LB40 / Leuchte13NL RB3.
Am i doing something wrong?
Controller 09
Adaption
Leuchte2SL
         Dimmwert GH2 = 10
Leuchte3SL
         Dimmwert GH3 = 10
Leuchte4TFL
         Dimmwert EF4 = 127
Leuchte5TFL
         Dimmwert EF5 = 127
Leuchte20BR
         Dimmwert EF20 = 18
Leuchte21BR
         Dimmwert EF21 = 18
Leuchte23SL
         Dimmwert CD23 = 100
Leuchte24SL
         Dimmwert CD24 = 100
Leuchte25KZL
Works nice !!!!!
Coding with VCDS :
Turn on mirror amber light with interior light :
Controller 09
Adaption 10
Leuchte16BLK SLC11-Light_Function_G_16 to Interior light
Leuchte16BLK SLC11-Dimming_GH_16 set the dimming in % (i have 100%)
Leuchte17 BLK SR A72-Light_Function_G_17 to Interior light
Leuchte17 BLK SR A72-Dimming_GH_17 set the same dimm (100%)
Dim LED Number Plate when you open the safe :
Controller 09
Adaption 10
Leuchte25KZL HA60 Light_Function E 25  to "rear lid open"
Leuchte25KZL HA60 Dimming EF25 set the dimming in % (i have 10%)
