3C8035730E - missing icons on maxidot
Hi Guys,
Fitted a new 3C8035730E module to my car to replace a very old 5K0 module as my HFP modules gone into the wives fabia. Working really well with the WiFi AP setup and hotspot working.
I have noticed that the maxidot has some missing icons and showing underscores instead:
How do I go about correcting this? Everything else (inc voice control) works correctly.
I wonder if they are unsupported graphics on these newer modules? RainbowFire (Alex) has just fitted this module to a pre FL Octy (which works courtesy of a polar FIS). Might be worth asking him if he has the same? I don't on my 08 Octavia but then I only have the D revision.
I hear someone mention my name? Nothing good I hope ;)
Seriously (for a change) my display is complete, no issues. I am using a PolarFIS Advanced (PF03), not just for getting the bluetooth working, but becuase there's a load of shiney shiney stuff that happens too. :) :) (Nothing, I mean nothing, has enough toys to play with.) Mine's a 07 plate, so even older than Adam's ;)
Adam, that looks like a BAP MaxiDot anyway (not the old skool DDP), so I'm not sure what compatilbility issues there could be. :S :S
Nathanio, is everything ok if you unplug the bluetooth unit?
Good shout. I think its the 3G icon, media player, battery and wifi from what I can tell.
I'll also do a scan with Carista
Sure is, when I had the previous non rSAP unit in it displayed all the correct symbols. The only symbol it struggled with was the Roaming symbol when I lost 3s 3G signal and went to orange 2G
My point wondering if the new unit uses different graphics not supported by the older maxidot not so much the ddp/bap thing. But it seems not if Alex's older maxidot handles them. Still seems to be graphics related so I wonder if a factory reset will help?
On the module? It was brand new and still sealed (£90 delivered from Poland)
DOA is not unknown.
Incorrectly coded could also be the case. It can be reset via the headunit usually.
  • 8 months later...
Coming back to this. I have just corrected the coding on VCDS as  it didn't have a workshop code in the coding. This has cleared an error I had on there but still no icons.
Is there any settings in the instrument section that might control this?
It's down to the cluster software, it doesn't have the icons that are used by newer BT modules.
If you're lucky, there might be an update as there is for some Octavia clusters. Got a full autoscan?
I have but I'll need to get it off the other laptop. I'll grab it tomorrow.
Done a little more digging and at a guess probably has 3T2920841B running SW 0106. At least based off it being a '58 Plate Superb 1.8 TSI Elegance'.
If that's the case there is no obvious update for your cluster. There are reports that SW 01xx clusters can be updated to SW 0305 but I've never seen a flash file for it so I wouldn't put too much trust in these... Nor do I know if SW 03xx has the icons.
I think SW 04xx upwards should have the icons included and if not a cluster running SW 04xx can be updated to SW 06xx which definitely has the correct icons.
Thanks for the looking around. Here is the autoscan data:
Thursday,28,January,2016,08:37:18:35773
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
www.Ross-Tech.com
Mileage: 149570km-92938mi Repair Order: 2016-01-28 AutoScan
Chassis Type: 3T (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 36 37 42 44 46 52 55 56 62 72
77
VIN: TMBBB73T199014760 Mileage: 149570km-92938miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine ( ) Labels: 06J-907-115-BZB.clb
Part No SW: 3T0 907 115 HW: 1Z0 907 115 B
Component: 1.8l R4/4V TFSI 0030
Revision: A2H12--- Serial number:
Coding: 0203000318070160
Shop #: WSC 35110 377 09999
VCID: 6ED3A9D3791CB84E93-803A
No fault code found.
Readiness: 0000 0100
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 3T0 907 379 A HW: 3T0 907 379 A
Component: ESP FRONT MK60 0102
Revision: 00H11001
Coding: 0004738
VCID: 3B7550877AEE1DE664-806E
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3T0 907 044 N HW: 3T0 907 044 N
Component: Climatronic 122 0102
Revision: 00003001
Coding: 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_SK12.rod
VCID: 3D715E9FACFA13D65A-8068
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 A HW: 1K0 937 087 A
Component: BCM PQ35 H+ 020 0358
Revision: 00020000
Coding: 48990AB8F873F1C040080084310089A403F91BAE63308D605C4040000000
VCID: 2F6D74D77E96F146D8-807A
Subsystem 1 - Part No: 3T2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 26080 22 0602
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 090908 05 54 0402
Coding: 0730ED
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K0 951 605 D
Component: LIN BACKUP HO H08 9001
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 3T0 919 475 HW: 3T0 919 475
Component: PARKHILFE PLA H07 0002
Revision: -------- Serial number: 66430823903237
Coding: 001004
VCID: 7AFB9583F554E4EE3F-802E
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 3T0 959 655 HW: 3T0 959 655
Component: J234__LAJ VW10 HI 1815
Revision: 17013000 Serial number: 003CCPHKDH7/
Coding: 0016714
VCID: 7EF39993297CC8CE03-802A
Subsystem 1 - Serial number: 6333FTS606282318
Subsystem 2 - Serial number: 6343FTS600283402
Subsystem 3 - Serial number: 6353ETS6F35KUVNP
Subsystem 4 - Serial number: 6363ETS6N73LUVNP
Subsystem 5 - Serial number: 6373JTS62J0MUVNH
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0000731
VCID: 76E381B3014C808E5B-8022
Subsystem 1 - Part No: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H06 0009
Coding: 00000130
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 3T2 920 940 B HW: 3T2 920 940 B
Component: KOMBI H28 0024
Coding: 410F00
Shop #: WSC 35703 895 09999
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 336578A79ABED5A6BC-8066
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K08825010B
Coding: E9A1FF064006023303
VCID: 356146BF5CCACB9692-8060
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H28 0024
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 HW: 3C8 959 760
Component: J810 0801
Revision: 00002000 Serial number: 00000000000000
Coding: 0000003
VCID: 72EBBDA36D249CAE77-8026
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 A HW: 3T0 035 680
Component: RNS-MID H03 1304
Revision: AB001001 Serial number: SKZ6Z7H8249118
Coding: 040004000004008300
VCID: 2E5369D3799CF84ED3-807A
Address 42: Door Elect, Driver (J386) Labels: 7N0-959-793.clb
Part No SW: 7N0 959 793 A HW: 7N0 959 793 A
Component: TSG FA H03 0190
Revision: Serial number: 0000100206781
Coding: 011D0220DE01121002
VCID: 408F276BD3087E3E31-8014
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 194 2301
Revision: 00H15000
VCID: 2A5B65C38574946E0F-807E
Address 52: Door Elect, Pass. (J387) Labels: 7N0-959-792.clb
Part No SW: 7N0 959 792 A HW: 7N0 959 792 A
Component: TSG BF H03 0190
Revision: Serial number: 0000100194921
VCID: 3F8D2497AEF601C648-806A
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0133
Revision: 00H04000 Serial number:
Coding: 1377095
Shop #: WSC 53092 001 1048576
VCID: 34677BBB57B0D29EA5-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000021
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r S004
Coding: 00000021
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 62: Door, Rear Left (J388) Labels: 7N0-959-795.clb
Part No SW: 7N0 959 795 HW: 7N0 959 795
Component: TSG HL H02 0190
Revision: Serial number: 0000100233354
Coding: 010C00200001221002
VCID: 0109E26F9882B7367E-8054
Address 72: Door, Rear Right (J389) Labels: 7N0-959-794.clb
Part No SW: 7N0 959 794 HW: 7N0 959 795
Component: TSG HR H02 0190
Revision: Serial number: 0000100218014
VCID: 55A1E63F3C8AEB9672-8000
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 025 0983
Revision: -------- Serial number: 35502105232301
Coding: 020000000100010000000101
Shop #: WSC 02325 785 00200
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi_SE36.rod
VCID: 254196FF246ABB1622-8070
1 Fault Found:
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 220
Mileage: 149527 km
Date: 2016.01.28
Time: 07:25:47
End-------------------------(Elapsed Time: 02:36)--------------------------
Edited by john999boy
Details removed
Please edit and remove the VIN from the posting :)
There aren't any updates that I can see for the clusters you have I'm afraid. The only was that you're likely to sort them is to replace the clusters which is probably too much hassle with the immobiliser and odometer.
RainbowFire, any reason not to post the VIN? They are hardly secret as anyone walking past the car can get them...
I can't edit the post so it's there unless a mod can remove it.
Thanks langers. Looks like I shall be living with it then :D
I don't know the source, but it has always been said not to put VIN's up as part of a scan. Could be group paranoia, could be a legit reason......am only passing on what we've been told in the past.
  • 9 months later...
cluster  SW is too old to support  latest BT module
Know that issue for a while
