How to replace the beam bulb on Skoda Octavia
I want to chenge on my Skoda Octavia 2 FL the beam bulb. Who can tell me how to do it ?
You will need to remove the headlight,its a easy job,open bonnet & undo the plastic nut holding the headlight in,pull the lever on the side of the light (near where the grill would be with the bonnet down) & pull out the light,un-clip the wiring connector & access to whichever bulb you want is easy.There is a guide with pictures in the octavia section if you have a look there.
