Sat nav for 2012 superb
Does any one know if I can fit a sat nav module to a bolero unit
I don't believe so, I think the entire unit would have to be replaced with either an Amundsen or Columbus (which asides from the cost, is pretty easy to do)
Ive just done this to mine 1st to rns315 then to columbus but you will need gps aerial & mic with loom also maybe new steering wheel buttons plus some one with vcds to code it into the car.
If you need it coding in I'm local in bham & i have vcds so i can code it in for you.
Yes, you can add Android based external GPS unit but the cost is higher than Columbus. Check www.wondeproud.com. I have such solution in my Columbus so I can switch between original SKODA navigation and Android.
Edited by pab567
Thanks for replies
Not a great fan of the satnav Columbus system here.
