Catch-can problems
Evening all,
I installed my catch-can the other week and I keep finding the below pipe to the turbo intake has come out....
91DD8A34-6DD0-4716-B3E5-A90357800171_zps
Any ideas how I can make it stay in?!?
It should be a tight fit and the bit it keeps popping out of sucks in as well.
I can only assume the pipes to small?
I've used the original bits that originally connected to the intake... Just removed the little pipe goes between the top of the block to the intake?
I did get the exact pipe I was told to on here, but hey!
Does anyone have a link to the correct size pipe?!
Can you take a photo further out please showing the engine bay and also where the catch can is.
I'm wondering if there is not enough slack in your hoses and movement from the engine is causing it to pull out that connector.
That's not a bad shout. Will post up in once I've got to my next stop.
I already have a picture in photobucket, awesome!
5893AABA-6AEA-4E92-89F0-FDD404E7357E_zps
I think that is your problem.
Whilst you are looking under the bonnet get someone else to rock the engine by bringing up the clutch slowly in first and reverse whilst the handbrake is on tight. See how much movement you are getting.
Yeah looking at that picture it does seem plausible. I'll put a longer pipe on later this evening.
Cheers mate, much appreciated. :)
That's what I mean by the pipes to small. Not the inter diameter of the pipe, the length of the pipe is to small.
Ah my bad :p.
Cheers dude.
Is heater hose oil resistant?
I had the same issue, the best fix is to make a bracket that's connected to engine to mount can on, then the can moves with the engine so doesn't pull on the hoses ;)
That was my original plan tbh, but ended up doing it this way for ease.
I may look into that for the long term fix.
I have no idea, but was told it was suitable? I would happily change it if it's not.....
That is only suitable for a max temperature of 65 deg C, not sure if that is enough for hot oil vapours.
Heard stuff about it seeming though.
Sorry, what do you mean?
So it does, good spot. There's some clear reinforced stuff I've seen but I don't think id like the look Of it in the engine bay.
Sorry, 'heard about oil SEEPING through hose not designed to hold it.' Sodding auto correct and terrible grammar.
Ah now I get ya.
I guess it'll be obvious if it's happening?!
Please feel free to post up some recommendations for suitable hose and maybe some connectors to re-route the pipe work round the back and down the side of the engine people :)
Ah now I get ya.
I'm prob just over cautious, but scared the pipe would degrade and start to come apart with the bits going into the intake....now I await the response from people telling me to stop being such a div.
