Knocking when steering whilst stationary
My immediate thought was that it sounds like the inner rod joints inside the rack bellows but you said they've been changed?
The car wasn't running when I tried it ?? Only went left to right quickly . Could it be the pump dry when not running ,?? I thought rack .. How does the rack go onto the column ? Pinch bolt ??
I would check the steering fluid level, just in case
At the end of the steering column is a link piece with a universal joint at each end.  The one that connects to the pinion on the rack has a pinch bolt.
It would appear that the steering column, the link piece and the universal joint is one part.
SN
