Instrument cluster swap - immobilizer adaption error
Dakota558
I´m trying to replace the instrument cluster in my Octavia 2 with a new (used) one with maxi dot display. I managed to get the pin for both clusters, and I´m following a guide a found on another site (quite similar to what is described on Ross-tech: http://wiki.ross-tech.com/wiki/index.php/Immobilizer#Immobilizer_Generation_4).
On the adaption menu (10) under immobilzer menu (25), I´m supposed to wait until "immobilizer adaption active" changes to "immobilizer active", the go to channel 50 and enter the pin of the old cluster. When I press test, ERROR comes up under Test value and a message comes up saying "No response from controller".
I´m using version 14.10.2 of VCDS, and both pin codes are tested.
Any suggestions?
Any suggestions?
Any reason why you are using old software? (the latest release is 15.7.0)
I've now tried with the newest version of VCDS with the same result. I've posted on the rosstech forums as well, hopefully someone will be able to tell whats going on. I'll post any results here when I get them.
