VCDS can't enable Driver Alert System
certainly seems to point that way doesn't it? and now we're wondering why my car controls all light up even when the lights are off. Gotta love these cars
  • Replies 62
  • Views 24k
  • Its supposed to take data from the steering angle sensor and ESC system and using some algorithm determines when it thinks you are tired. It no doubt factors time into that equation too. I've got it
  • I've just had a look, and yes, I have the 'Driver Alert System' option in the settings. It can also be enabled/disabled too. I suspect something to be amiss if yours doesn't turn on/off.
  • Have you got the log that was kept open during all of the coding session so you have a record of all the changes? What version of VCDS was being used?   If you have the log, PM it to me and I'll ha
Can I check with anyone with a MY16 vrs that they have the option for Driver Activity Sensor? I have checked 2 other cars.
2013 vrs has the option
MY16 SE L has the option
MY16 vRS (mine) NO Option :(
My MY16 VRS doesn't have an option for that
So same as me?
Can you tell me what options you have under the driver assistance settings in car settings?
Here you go
See what happens after the dealer turns transport mode off properly on the BCM if the error code won't clear after going in to 09 and clearing it from there
H Andy has suggested on pm that clearing the fault the way I did it might not work . I will have a go another route and see if that works
Sent from my LG-H815 using Tapatalk
Here you go
See you enabled traffic sign recognition! And you only have lane assist and traffic sign as those 2 options.
But only had lane assist before
Ok, I think the driver activity sensor option came on when we were messing about with traffic sign recognition. But if you successfully turned it on without the rogue option then maybe I should try it again.
Edited by Iamholam
So it seems that the fatigue sensor is missing on at least 2 MY16 vrs. Any more?
Sent from my GT-I9505 using Tapatalk
its a fairly pointless thing anyway, I think it has only come on once on my MY14 model.
I did tell him that  :D
We should all listen to you more!
According to the brochure (which is always right LOL) SE & upwards have fatigue detection as standard.
I'd be back to the dealer asking why there is a fault code for transport mode that won't clear and where is the fatigue detection setting in the infotainment?
What value is against this adaptation channel on 5F
Car_Function_Adaptations_Gen2-menu_display_weariness_recognition
maybe they have removed the option to turn it on or off in the MY16 models?
No I actually think it's missing, we managed to turn on the option in the MIB2 but then when we pressed that it said the function was not available. We thought it was the coding but Andy has double checked and it's OK. And when we removed the traffic sign recognition the option in the MIB2 disappeared.
I'll get together with Iamholam soon and check out that value you've asked for Andy.
There were errors that appeared last night, not sure what they relate to and whether they are linked to the transport mode.
Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
   Part No SW: 5E0 907 044 Q    HW: 5E0 907 044 Q
   Component: Climatronic   H04 1002
   Revision: 00001K07
   Coding: 02110104000100011005000000101000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ACClimaBHBVW37X 004131
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 336E16899A0DD8A69B-8066
1 Fault Found:
1048838 - Functional Limitation due to Energy Management
          B10CD 00 [008] -  -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 98
                    Mileage: 1499 km
                    Date: 2015.08.31
                    Time: 22:01:44
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Component: BCM PQ37BOSCH 028 0162
   Revision: --------    Serial number: 86581106150752
   Coding: 0F500A42C24722FB07A04082B10C07280000000000000000000000000000
   Shop #: WSC 73430 790 12345
   ASAM Dataset: EV_BodyContrModul1UDSBosc 015002
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 030E86498A2DA8264B-8056
   Slave 1:
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150530  041 0570
   Serial number:         150604114938
   Coding: 065DDD
   Slave 2:
   Subsystem 2 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S5Y15M06D25H23M29S50
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY1505106VS
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000032517038
   Subsystem 5 - Part No SW: 5E9 959 591 B    HW: 6R0 959 591 D
   Component: J245 PS24.402  H03 0004
   Serial number: 0000FST000CDLU400000
   Coding: 991800
   Subsystem 6 - Part No SW: 5E9 959 591 C    HW: 8V3 959 591 A
   Component: J394 PS24.402  H03 0004
   Serial number: 0000FST000CXZNV00000
   Coding: 991800
3 Faults Found:
534549 - Databus
          U1121 00 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 71
                    Mileage: 1499 km
                    Date: 2015.08.31
                    Time: 20:47:40
535060 - Databus
          U1123 00 [009] - Received Error Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 78
                    Reset counter: 71
                    Mileage: 1499 km
                    Date: 2015.08.31
                    Time: 21:28:21
527872 - Transport Mode Active
          U1105 00 [008] - -
             Freeze Frame:
then in the summary it said 5F-Information Electr. -- Status: Malfunction 0010
but when you go to the part of the log where 5F is detailed it says no fault code found
odd
The fault on the climate is normal, the car is trying to stop the battery being flattened.
Clear the others and see if they come back, they are more than likely caused by the HBA and TSR changes you made.
Sent from my HTC One_M8 using Tapatalk
Update VCDS as well :)
What else did you code using vcds? Anything you recommend?
I only did HBA, cornering fogs and TSR, mirror dip is useless as it never goes back where it came from in my experience!
I did HBA and corner fogs.
If I do tsr, should hopefully get to the same result as you.
Mirror goes back 90 per cent of the time, if it doesn't then flicking the switch from l to o does the trick
Yep, 90% isn't good enough in my view
