Felicia exaust is confusing me
After the back box fell of my felicia fun I decided to swap it with my doner cars exhaust while doing this I noticed that the silencer had seen better days so was going to replace both. After several sprays of wd a lot of banging with rubber mallet wiggling and slice to finger exhausts were of. Then the trouble started I fit the silencer with abit of persuading with the mallet and it didn't seem to line up with the existing brackets about an inch out needs to go towards the front of van. Thought will be ok just stick out back a little more but when fitting the back box it seems that the whole exaust needs to come towards back of the van as back box is protruding passenger side rear springs. Completly confused as why would it be a different exaust was of a skoda felicia 1.6 Glxi can I just put an extension piece on if so will it affect mot
The pickups have a diffrent back box to the estate models just get a custom made exaust..
The estates are coil over shock, so if you put an estate back box on a truck it will try to go through the inboard springs on the rear axle.
www.buypartsby.co.uk sell the right one, ain't expensive.
There is nothing confusing.
Rule #1 says "compare new part with old part" or even better measure both.
Suddenly all will become clear.
Would of measured but completely rotted and snapped of never to be seen again
