cutting out whilst driving and idling, fan not coming on
Dear All
  First post - have read a few threads over last few months but perplexed enough about my latest problems to join up and ask the pro's..!
I have the 1.4 mpi 8v petrol 2003 fabia. a year ago i had some problems that i traced to the thermostatic sensor, replaced it and all good for about a year. - Have read many threads on here about this item.
However, recently I went through an automated car wash and couldnt start the car afterwards - had to push it down the road and waited half hour for it to dry out before it would start. It was ok for about a day until it suddenly started to cut out intermittently whilst driving. Noticed that the fan has also stopped coming on - not sure how its related though.
So I checked the fan was working by short circuit and it was ok so then replaced the switch/sensor in the rad as thats what the 'Haynes' manual said would be the problem. Fan still not coming on...?? anyway the car is not running right at all and worried that it could just cut out again. at the moment i cannot seem to replicate the fault but find it strange that the temp dial does not go off the scale..i.e engine overheating issue....as the fan is not coming on when stationery. The temp dial only ever gets up to half way....however, it was cutting out whilst idling when it first occured a couple weeks ago. - needless to say havnt driven it for a while and cant work out whats going on..! and desperate to avoid garages as can do most work myself.....even bought a VAG diagnostics tool - no codes....(..??
Any ideas peoples?
Much appreciated
Adam
Vcds live data may help the situation
Coilpack got wet and is breaking down?
Thanks for responses
Toxicvrs - Im unfamiliar with vcds process and what it will tell me? more info would be great!
sepulchrave - i replaced the coil pack and spark plugs a year ago, if it is this then what should be done ?
many thanks in advance.
Called AA out tonight and traced problem to the crank shaft sensor - wiggled it about a bit ! apparently also a common fault on Renault clio
the fan worked also albeit at 91 degrees but all solved I hope when I get a new crank shaft sensor in the morning....
  • Sponsor
What temperature do you think the fan should run at?
Hi Wino - sorry i think there are 2 fan positions, the first at 88 degrees? - I was thinking that the first position was not working....but seems like its ok now. This turns out not to be th eproblem as I have now experienced many more since.....see this thread. Any help much appreciated......
http://www.briskoda.net/forums/topic/372678-p1570-p1172-p1544-p1156-fault-codes/
  • Sponsor
I've got a feeling that the first fan speed doesn't come on until the coolant temperature at the thermoswitch reaches 95C.  Will check out your other thread tomorrow.
Yes you could well be right, im beginning to think it may be more to do with the key/ignition/instrument cluster/ECU - as per this thread and moisture problem as the car did not strart right after going through the auto car wash and then it has been intermittent...just wish I knew which way to approach it.
http://www.briskoda.net/forums/topic/101275-fabia-immobiliser-skoda-cant-even-fix-it/
I had this problem last year then again this year when it became permanent. It seemed to happen frequently on very hot days. Well after waisting money like everyone else having wiring checked and the ignition barrel replaced, I decided to send my Instrument Cluster/Panel (which is very easy to remove yourself) off for testing .
Turns out the main motherboard PCB had moisture damage and a refurbishment was required. They did have the same model in stock for £137, but since I had sent mine off already and would have to pay for the diagnostic anyway I decided to get it repaired which cost me £200.
I have not received it back yet, should be in the next week, but will post here when I do.
Heres hoping this sloves the problem.
For anyone wondering, I sent it off to the following people:
http://autotekelectronics.com/autotek/
Updated 06/09/12:
Well I got the instrument panel back and have been using the car for a week now with no problems at all, looks like it is fixed for now.
