First major repair....
The first major repair/replacement at 150,000 km service: new front brake discs and pads and an exhaust temperature sensor. Brakes were still the original ones, never replaced before. There is no need to do anything to the rears.
Brakes isn't really a "repair" - they're serviceable items.
Thats very good going on the brakes. I've been very impressed with my cars reliability. My rear brakes are just getting done now at 50k.. but im about to replace the second setup ive had on the front!
but "an exhaust temperature sensor" surely is?! 'Major replacement' is stated by the OP and if nothing else has needed doing at all, comparatively, the front brakes could be seen as major. ;)
If you are a competent DIY’er yearly remove brake pads clean up & refit with copper grease where necessary.
I have just removed my discs & pads, cleaned & refitted. Clean up disc as well, remove slider pins & lub that too. All still looks like new (well almost)
Now at 11,000 miles.
Edited by Carlo diesel
Well done on the brakes, our Spaceback has just had all four discs and pads replaced at mere 13,000 miles  :S
They had gone very rusty despite regular use.
TP
Plumber. Ouch, As you can see mine at 11,000 miles are almost untouched.
I'm not heavy on my brakes.
My van has just turned 32,000 miles 4 years old & just fitted new discs & pads to fronts.
It really does pay to remove them every year, clean, lub & refit. Stops any sticking pads & rust build up.
Preventative maintenance.
Ouch is one way to describe it, the car I forgot to say was not much more than a year old either.
Thankfully SUK agreed with me that such premature failure should be a warranty issue and I'm awaiting a refund from the dealer.
TP
150,000 km is impressive indeed.You are a man with a light foot on the brakes.
My experiece is that OE lubricants used on the guide pins dries out. Even the Permatex AntiSeize I use seems to dry out. Annually dismantling, cleaning and lubricating is a good advise for troublefree brakes.
I have used this for a few years:
Permatex-CeramicExtremeBrakePartsLubrica
Had that problem with the last Yeti, the rear callipers kept jamming up. The white paste used at the factory very quickly turned to treacle, plus the rubber sleeves on the guide pins swelled exacerbating the issue. Fitted new pins but by the time I sold the car the callipers had started sticking again.
TP
TP
I have not experienced the rubber sleeve swelling in contact with the Permatex grease.
