Winter wheels advice
Hi folks. I currently have an '08 plate Octavia Scout which has the standard 17" alloys. In my shed I have a full set of Goodyear winter tyres, which are 205/55/16. Can anyone tell me what VW group 16" wheels(other than those from other Octavia IIs) I would need to buy to fit the winter tyres to?
Regards
Marge
I got a set of steel wheels off a VW T5 Transporter and they fit perfectly.
Pretty much an vag 5x112 16" inch wheels will fit. You want an ET around 50. I have a set of audi wheels which are Et 42, which are fine.
Sent from my D5803 using Tapatalk
I will be sticking a set of 16 inch steelies fitted with fallen eurowinter tyres up for sale very shortly. Loads of tread on them.
Regards
Marge
Anything with a 5x112 PCD and 57.1mm centrebore - so anything off a Golf/Jetta/Passat/Superb, etc or an Audi A3 or the earlier A4.  Later A4s have a 66.6mm centrebore & you need some hubcentric rings to make them fit nice (they are cheap to buy off ebay).
width will be anywhere from 6" to 7.5".  Offset will vary and you can run almost anything in 6"-6.5" ET35-60.  7.5" will be ET40-55.
Here's my old Scout running 16 inch Audi A3 wheels
They are 16" x 6.5J, ET50, running 205/55 R16 winter tyres, not pretty but did the job.
Mk2 Octavia are 5x112
VW t5 transporters are 5x120 pcd (same as BMW/ Range Rover). Your steel wheels will be from a VW Caddy not a transporter
Most other VAG are 5x112 (except Q7 and Toureg which are 5x130 because they are built on the Porsche Cayennne chassis and the smaller cars polo/ fabia/ ibiza/ UP!/ citigo/ A1 etc which are 5x100)
You need wheels from a mk2 octavia, mk5/ mk6 golf, Touran, A3 2005>, A4/A6, Passat, 2k caddy van etc
Edited by mattvrestate
I run Audi A4 alloys in 5x112 6.5j 57.1 et42 with 205/55/16 tyres and they work fine on my scout.
I did the same, but they are sold now
The car would go anywhere, in all conditions
I thought they were from a T something. What about from a T4, would they be correct? It was some time ago and memory failing me.
Could be. T4s are 5x112
Ah, must have been a T4 then.
Thanks for all the replies. Am pondering over some steelies, but wonder if it might look rubbish with them. At least I know what to look for now.
Regards
Marge
Regards
Marge
I actally liked the look of my car with the steelies and no trims, especially when the car was dirty.
Regards
Marge
Simply find one Skoda with steels on the street and take a look. These steels rims are more or less the same and you will understand how your car would look. Actually it's a different thing but it doesn't look bad at all :)
