Most amount of mods?
So just for ****s and giggles whos got the most mods? I know I'm going to be bottom but also gives people ideas
I'm on 3
*pressed plates
*wind deflectors
*facelift badges
Things to come include
*coilovers
*wheels
*splitter
*Leds all round
And a new more....
Erm I am sure the lists will be massive!!!
Off the top of my head I reckon most will be about 20
40 here, but I'm sure there's people with a lot more
40? Please list some as that's impossible? Unless there's loads of tinnnyyy ones haha
Wrapped grill. Matt black.
New skoda badge front and rear
New vRS badges front and back.
Window tints. Limo.
Middle and backbox delete.
LED interior bulbs.
Hid conversion kit
Fly eye headlights.
Vrs decals on calipers.
Lots more planned........that leaves me on 9 at the moment. I've prob forgot a few more?!
Robs got and Octy which is only 10% OE Octy from what I can make out
My factory spec is as follows:
- Alcantara vRS Sports Upholstery (black seats with red stitching).
- Curtain Airbags
- Electric Sunroof
- Heated Front Seats
- Light Assistant with Rain Sensors and Auto Dim Rear View Mirror
- Maixdot Trip Computor
- Mobile Device Interface
- Rear Parking Sensors
- Sunset Glass
- Xenon Headlamps with AFS II
- I-Pod connection cable
Mods are/were:
#1 OEM Matt black mirror covers (now replaced with gloss black)
#2 De-badged the "Octavia" script from the rear.
#3 OEM Sharan stubby aerial mast.
#4 OEM GTI skinny space saver spare.
#5 Fiscon Bluetooth.
#6 OEM Audi S-Line gear knob with red detail.
#7 OEM Columbus Navigation LED version
#8 Integrated electric gate transmitter
#9 Bilstein B16 Coilovers (now with H&R)
#10 OEM TT alloy wishbones (now with S3 wishbones).
#11 OEM TT wishbone bushes.
#12 Autotech 25mm hollow rear anti roll bar (ARB). then added SUPERPRO bushes , then replaced with new H&R bar
#13 OEM Aspheric door mirror glass.
#14 OEM Shark fin roof antenna
#15 VCDS tweaks (cornering fogs, columbus on maxidot, emergency brake flashing via turn signals, disable "140km turn on main lights").
#16 OEM TTS Short shifter.
#17 OEM Gloss Black mirrors.
#18 OEM Multifunction Steering Wheel.
#19 Neuspeed RSe07 wheels 8x18 ET45
#20 OEM accessory Rear Bumper Protection Film
#21 Milltek Catback
#22 Brembo brake calipers (Porsche 986)
#23 H&R monotube coilovers
#24 OEM S3 alloy wishbones
#25 Superpro camber adjustable ball joints
#26 H&R rear anti roll bar.
there's a probably a few i've forgotten.
car is back to stock configuration now, as i have a new car on order :)
Some big mods, some small mods...
40 mods would be about right :)
Engine and Tuning:
The car is Shark stage 2 (280 BHP / 330 Lb/Ft torque); with the following engine parts fitted:
- 3" Pipewerx 200 cell sports cat downpipe
- Milltek resonated catalytic converter back exhaust
- THS FR3 engine torque mount
- Audi S3 Intercooler
- Audi S3 Intercooler hoses
- Audi S3 Revision 'D' Diverter Valve
- Neuspeed Turbo Outlet Pipe
- Neuspeed Intercooler Charge Pipe
- Neuspeed P-Flo Intake
- Shark stage 2 software
- Forge Silicone Throttle Body Hose
- Revision N PCV
- N80 Valve
- NGK Iridium Spark Plugs #7
- Audi R8 Coil Packs and harness
- ECS Tuning aluminium oil filter housing
- ECS Tuning magnetic sump plug bolt
Transmission
- Forge short shift kit
- New Helix Organic Clutch
- Fuchs Sintofluid
Suspension
- Bilstein B8 dampers
- H&R -50mm Lowering springs
- Audi S3 Lower control arms/Bushes
Wheels
- Genuine Audi Ultra Sport 18x8J Alloys, refurbed in Anthracite
Brakes
- EBC Front grooved disks
- Yellow Stuff pads
Interior
- Pioneer DVD double din HU
- Bury Car kit
- New Superskoda rear blinds
- Briskoda B sticker on windscreen   :)
- All bulbs changed to LED's
- Colour coded fascia trim
Exterior
- Black grille
- Black mirrors
- Superskoda honeycomb lower front grill
- Stone chip level raised and resprayed on Sideskirts to prevent rust
- Depo Headlights (Painted internally black)
- LED Number plate lights
- Briskoda stickers   :)
VCDS Coding
- Auto lock above 10MPH
- North America DRL Setting
- Dual Rear fog lights
You got leds in drls?
Ps I would say that's more then 40 hahahah
My signature has mine, around 15, some bigger than others.
Damo do you have VCDS by any chance? also what is North America DRL Setting?
Edited by Tom1984
Scandinavian DRL = dipped headlights, side lights, tail lights and number plate lights - on / off with the ignition.
North Amercian DRL = dipped headlights only - on / off with the handbrake (ignition on).
Both settings can be altered to use the front fog lights instead of the dipped headlights. The brightness can be adjusted too.
I'm afraid I dont have vcds.
Only Carista
My front fogs are on at 60% as drls, and go off when the handbrake is applied
Most of my mods are in the classifieds now
