Overheating when in slow-moving traffic problem
Recently, my car (55 plate Skoda Fabia classic) has been overheating in traffic.
Upon googling, it appears that the problem is with radiator fan not doing its job or there's a blockage in the pipe. Is that all? Is there any other potential casues I should be checking out?
And how much should I expect pay to fix this problem? Is this problem DIY-able?
Edited by JoeBloggs
Thermostat perhaps ?
When parked up rev the car and see if the fans come on when it gets hot
also test fuses I'd say for the fan
It's process of elimination or trip to a mechanic
Does coolant level drop ?
Thanks for the thermostat suggestion.
I'll check whether the fan comes on if the car is revved up. What does it mean if it does/doesn't come on?
Coolant level didn't drop.
Check the relevant fuse before testing (as above) whether the fans are working or not.
DB
Edited by mogwye
DB
Which fuse should I buy for this? I assume it's cheap enough to replace without needing to check whether it's working or not.
When searching for Fabia Info on Briskoda - Use this Google search first by inserting what you are after between the * here*, copy & paste to try for future reference - site:briskoda.net *Fabia VRS Fuse Layout*
Here you go for the Fabia Fuse Layout.http://www.briskoda.net/forums/topic/294383-the-mki-fabia-fuse-layout-post-updated-with-bulb-types/
DB.
Thanks for that. I'll be sure to use search function every time an issue comes up.
Edited by JoeBloggs
