ignition barrel possibly worn
I think the ignition barrel could be worn
Other members of family turn key alright, but for me i think it feels worn, and it just doesn't turn that easy for me at times.
Doesn't seem to turn aswell as the VW, don't know if it because i think about too much, or just comparing it
But i feel like a new barrel is needed, have two keys but noticed one key blade  seems a little loose, after getting, another key cut as we all terrible with keys.
Skoda said it takes a month for a new barrel, i may take it to them to ask there opinion on it.
Hi. I recently purchased a 2009 Fabiamand I have had the same problem. Every time I took it into the garage they said they couldn't fault it. However I really struggled with it. Ordered the new barrel from the factory which took a couple of weeks as I wanted to keep the same key, just got it fitted and now it feels far better.
Mine will become a bit difficult on hot days, otherwise it's fine
i had few people struggle with mine, used graphite spray, good as new ever since
cars going in for a service, mechanic says he has some special grease apparently.
a new barrel aint mega money but can take four weeks to arrive, unsure how big/small of a job it is to change over.
i use dad vw and thats a doodle, this skoda has me plagued, good job its me daughters car, she thinks I'm mad
Mmmmm......
You shouldn't use grease on a cylinder barrel. Use Graphite powder sold by locksmiths.
When my the ignition barrel on my wife's Fabia started to play up last May I was quoted £238 - £328 by a main dealer and £195 - £265 by a VAG indie for supply and fit. Price variations were due to labour requirements - some wanted 1 hour, others 2 hours. Luckily the graphite powder has worked (so far).
Agree with that ......no way should grease be used in ignition/steering lock.
When I bough my car (a year old and 13,000 miles) the ignition lock was very stiff to turn. Skoda sold me a little spray of stuff like WD40 which fixed the problem. It is a very runny fluid and should flush any wear particles of dirt out of the lock. I would be tempted to use some WD40 sprayed in the lock using the thin red straw that usually comes with a new can. Spray, work the key in the lock and then spray again.
