Fault codes from vcds
Hi Guys,
I'm new to the forum and hoping someone can help. I previously posted my faults on the polo forum however people don't seem that helpful on there so trying here. I have a polo 1.4 tdi 9n3 which has developed a problem with the air con and has other faults too. From reading on here it may be that I have a dodgy connector which is giving the low load signal problem. As for the air con I have regassed it but it still doesn't work. Here is a copy of my vcds scan.
Cheers
Calum
Address 01: Engine Labels: Redir Fail!
Part No: 045 906 019 CA
Component: 1,4l R3 EDC 0000SG 7537
Coding: 00002
Shop #: WSC 00788
VCID: 56A37BDBB24CBB8E57-4AE8
WVWZZZ9NZ6Y167768 VWZ7Z0D0879525
1 Fault Found:
17911 - Load Signal from Alternator Term. DF
P1503 - 35-10 - Implausible Signal - Intermittent
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.lbl
Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
Component: ABS 8.0 front H04 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002190
Shop #: WSC 00788 785 00200
VCID: 010978875B42EC3652-5140
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 10
Reset counter: 244
Mileage: 155137 km
Time Indication: 0
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Q0 820 045
Component: Klimaanlage X0840
VCID: 6ADB3F2B16340F6EE3-5140
1 Fault Found:
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 00BK BN-SG. 1S34
Coding: 09358
Shop #: WSC 00788
VCID: 3C77C9732C2041DE41-5140
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 18 AIRBAG VW51 0P 0008
Coding: 12600
Shop #: WSC 00788
VCID: 2C57F933DC40D15ED1-5140
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 903 D
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 01432
Shop #: WSC 00000
VCID: 326BE74BFE6487AE9B-5140
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0B7L GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 00788
VCID: 70EF2D4330E8F5BEAD-5140
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10110
Shop #: WSC 00000
VCID: 6FED2E3F2DD6EA46B4-5140
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 H
Component: 1N Komfortgerát 0002
Coding: 00019
Shop #: WSC 00788
VCID: 408FBD8340C8253E1D-4B00
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 6Q0 035 152 A HW: 6Q0 035 152 A
Component: Radio BVX 005 0004
Revision: 00005000 Serial number: VWZ1Z5E2997335
Coding: 0020200
VCID: 285F052398B8FD7E35-5140
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Is that scan from after the re-gas of the aircon, or before?
The load signal fault will almost certainly be the standard wire breakage at the connectors on the bracket at the front of the gearbox. May even be able to see through the plastic engine undercover. Dunno if diesel engines have the same rectangular(ish!) hole:
Hi Wino,
Thanks for your quick reply and suggestion. I will have a look at the connector when I have time at the weekend and see if any wires are broken. I scanned the car before the re-gas, cleared the codes then re-gassed the system then scanned it again and the same faults appeared.
Hi Wino,
Hmm, see if you can locate the sensor (something makes me think top of offside chassis leg area, but it's late, I'm tired) and check for any wiring that looks like it might be a bit sketchy.
Have you had a look at the compressor pulley to see if all parts seem to be rotating together?  There's a fault condition where the compressor 'fails safe' by tearing a rubber coupling which means that even though the pulley is turning, the main shaft of the compressor isn't any more. Not sure how easy that is to inspect in your engine bay.
Thanks for your help! Once the undertray was off, the connector was easy to spot using the pictures. As you rightly said two wires had broken off the connector, so I spliced in two fresh bits of wire and wrapped them well in insulating tape as I couldn't use the connector. Not had a chance to scan the car again so hopefully this has fixed the problem. I couldn't find the g65 sensor for the air con but I will have another look. You don't happen to have any pictures of where the sensor is located?   20151107_1152531_zpswigybb1i.jpg
Hi Wino,
Many thanks for your help! I have scanned the car and there are no load signal faults now. I got the air con re gassed at the garage using the automatic machines and it now seems to be ok. When I ran measuring blocks when the high pressure fault appeared it was showing 0 bar, but now it is showing 5 bar so I think I didn't re gas it properly oops!. However recently, when it has been cold I've been getting the low coolant warning symbol flashing and beeping. Thing is, it's wrong as I have checked and there is plenty of coolant, as it's between the min and max mark. Once the car has idled for 10sec or so, I turn off the engine, restart it, and the coolant light does not appear.
Is this a simple fix of getting a new coolant level sensor?
The coolant level sensor is integral with the expansion tank. You can't really access it to clean it either because of the tank neck design. However, a complete new tank is only around £15.
Thanks Lee! Stupid question, I presume I will need to order the level sensor separately, as the expansion tanks I have looked at online don't seem to come with this?
I believe that the tank and sensor are 1 complete unit so you have to order a new tank.
