vRS gone into limp mode
I hope one of those Service Managers at Skoda UK Customer Services are reading this.
Maybe others will post the Test Results they had that resulted in them getting a replacement engine and the variations between how the
'Official Test is done'.
This one in the Link was a Pass and 'No Oil Issue',  but look close at it, there was only 78grams of oil used,
only problem being the Technician never new the weight of a litre of Oil, and he followed the Cheat Test Report format.
You can get the results you want, but to get them while messing up a simple test is par for the course.
Just like with the Spark Plugs and failures.  VW were too busy making excuses rather than spending any time
on investigating Fundamental Design, Manufacturing and Quality Control Issue from their products.
Quick update after the 2nd oil consumption test the car will be having the oil spray jets fitted next Monday.
Picked up the furby today oil spray jets fitted on Tuesday so let's see how it goes hopefully no more oil issues. [emoji106]
Just don't get your hopes up yet. I had the jets fitted and it still failed.
Edited by LGM
  • 3 months later...
So story so far since the oil jet spray bars were fitted I've covered 3200 miles and the oil light has come on topped up 1 litre (Properly) this morning, it's definetly better than before
Stopped going into Limp mode?
Yeah it's all good they replaced the spark plugs as the one on cylinder 3 was cooked the cars as good as ever [emoji1303]
Funny that, mine was Cyl. 3 also.
Snap! Mine was 1&3, changed to the Denso spark plugs, used tesco momentum and not had any problems since.
Found #1 was a b***h to get to :( took a bit of fiddling but got it in the end.
Just had mine replaced on a service. Last time it was cylinder 1. This time cylinder 3. Cars the best it's been in a while.
Actually asked the chap to save the plugs for me to look at and no.3 plug was completely burnt out.
Sent from my SM-G925F using Tapatalk
any way of cleaning spark plugs up?
The best way to get the plugs clean is take the car for a run, let the oil get hot, then give it some spirited driving and once parked and cooled down the plugs when removed will look nicely clean. The issue is when you have an oil user and sooting up plugs and oil on cylinder 3 plug and you cook it, that is the plug that fails. Buy good plugs, check the gap and a thrashing a day keeps the misfires away. If you have a failing plug replace it.
3
Edited by GoneOffSKi
Going back many years, the advice then was to clean with a brass wire brush to remove the carbon deposits. That was in the days when Champion & Lodge were supremos.
Does that advice not hold good today, & if so why?
How can still clean a plug carefully any way you choose. Some people do not understand carefully though. When I was an apprentice we had a Champion spark plug cleaner that gave them a sand blasting.
